Floor Jack Placement on a Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by dragonfire_777, Aug 26, 2006.
  1. dragonfire_777
    dragonfire_777 New Member
    22
    I have a set ot mud flaps to install and will be getting the BT Stiffner plate in the near future. Based on what I read about installing the mud flaps, doing the rear ones requires the back wheels be removed to have enough working room and of course installing the stiffner plate will require jacking also.
    I have a floor jack I'd like to use when I do the installations. Does anyone have experience using this type of jack on a Prius and know where the best contact points might be to raise the front or rear of the car as opposed to one side then the other?
  2. catmother
    catmother IEEE Life Member
    23
    So California
    Jack points are shown in the owners manual. One each in front and rear on the car centerline. Look under the car, looks like a square protrusion, like a block
  3. santoro1
    santoro1 New Member
    132
    <div class='quotetop'>QUOTE(Dragonfire @ Aug 26 2006, 02:16 PM) [snapback]309808[/snapback]</div>
    I'd also use jack stands as well just to be safe. I installed the mudflaps a few weeks ago.. The fronts took 10 minutes each to do taking my time. Most of the time was simply organizing the tools, screws, etc. As long as it takes you to jack the car up, put jack stands up and stabilize the car is as long as it will take to do the job. Very easy..
  4. Don-RI
    Don-RI Member
    153
    Cumberland, RI
    You probably won't need a jack to install the BT Stiffner plate. I removed the old one & installed the new one by lying on my back & reaching under the car with the socket wrench. I could reach 2 of the bolts from each side of the car. A bit more reach with both hands helped start the first bolt on each side when installing the BT plate. Overall, pretty easy install.
  5. mtsarpilot
    mtsarpilot Junior Member
    87
    <div class='quotetop'>QUOTE(Dragonfire @ Aug 26 2006, 12:16 PM) [snapback]309808[/snapback]</div>
    I used a floor jack with no problem. Just position it to contact the car in the same place the Toyota jack should. The contact area of my floor jack is about the same size as the Toyota jack, so there was no concern of placing the stress to far from the proper location.
    Mud flaps go on very quick and easily.
    Have Fun.
  6. onerpm
    onerpm New Member
    477
    MN
    <div class='quotetop'>QUOTE(mtsarpilot @ Aug 26 2006, 11:03 PM) [snapback]310005[/snapback]</div>
    I think he wants to lift the entire end of the car at once, not one corner.
    rpm
  7. toddrav
    toddrav Junior Member
    32
    Washington
    Anyone have a picture of these 'center line' jack points? When I searched the manual, I only saw the single point near each wheel. Can't jack and use a stand with just one point per wheel.
