Floor Mat Fixation Grommets Disappeared?
Discussion in 'Gen 2 Prius Main Forum' started by jimolson, Oct 1, 2018.
  1. jimolson
    jimolson Member
    134
    55
    Indianapolis, USA
    Has any reader of this forum found a replacement for the round grommets that are part of the drivers side carpet where the floor mats are anchored?
    By 100k miles on the odometer both grommets disappeared, probably falling into the 1/2" diameter holes in the carpet where they once were crimped.
    Without these grommets, Toyota's plastic floor mat anchoring clips have nothing to anchor to.
    I have "Toy'ed" with the idea of purchasing 1/8" winged & spring loaded toggle bolts and retrofitting them with shorter screws and washers. However, I suspect these steel fasteners would be rusty and bleeding brown on my carpet by Christmas.
    I've wondered if anyone makes an oval-shaped blind plastic fastener that can be pushed into the grommet-less hole. The other end of this fastener would pass through the hole in the floor mat and secured with a threaded or snap fastener on the top side.
    SFO likes this.
  2. JC91006
    16,477
    8,394
    The dealer should have them?
  3. JC91006
    16,477
    8,394
    I actually have a couple new ones I can send you of you need them
    49,387
    maybe just get new carpets
  5. Max Johnson
    Max Johnson Junior Member
    Glendora, CA
    I am having this same issue, I just noticed that they're gone, cause I keep pushing my mat all over the place. How much would they cost at the dealer @JC91006 ? Or how much would you send them to me for (if you still have them). I have a 2008 prius btw.
  6. Max Johnson
    Glendora, CA
    UPDATE: Looks like they are about $5 or so on ebay, but I called my local toyota dealer he told me that they are listed 1 cent but that they are supposed to give them to you for free due to all of the unintended acceleration issues with the 2nd gen priuses. So yeah call your toyota dealer and ask how much they are, or if it's too far away just order one for $5 on ebay.
    They are called "floor mat retention clips/hooks" and part number is 08210-00820.
    Skibob likes this.
