Floor mat question
Discussion in 'Gen 3 Prius Main Forum' started by Malosos, Jul 27, 2018.
  1. Malosos
    Malosos Member
    117
    33
    Los Angeles
    Wondering if my 2010 has the appropriate drivers side oem floor mat?
    The mounting holes don't match up with the tabs, one or the other doesn't belong there, can someone enlighten me?
  2. fuzzy1
    10,477
    That looks like my 2012 mat, not my (long since traded in) 2010 mat.
    The older design used hooks that were hard to detach and remove for cleaning. The design changed in 2012 with much easier to use twist tabs on the floor, and different holes in the mat, apparently on much wider mounting centers.
    I'll guess that someone bought a replacement mat, and assumed that a 2012+ version is the same as the 2010-11 version. But it is not.
    #2 fuzzy1, Jul 28, 2018
    RMB and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Pretty sure @fuzzy1 scored a direct hit. It looks like the 2010-11 use the same kind of hook as the Gen 2. They are a bit of a pain compared to the newer ones on 2012 and above, but they are not interchangeable either.
    Malosos likes this.
  4. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    So this is what dealership charge as part of the maintenance routine every 5k check up. Oy dos mios
    Malosos and RMB like this.
  5. Malosos
    Malosos Member
    117
    33
    Los Angeles
    Thanks for the replies, definitely got different year mat, I'll keep my eye out for the correct ones that might pop up for sale.
    jerrymildred likes this.
