Flow of air design & Stones
Discussion in 'Gen 3 Prius Main Forum' started by mroe1, Dec 16, 2014.
  1. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    Maybe it's just because I am on the road a lot, as I drive 30 miles one way to work each day. Last month I had a stone hit my windshield so hard a crack ran across it, immediately. So I had the windshield replaced, as I had glass protection on my insurance. Now two weeks later another stone hit and I have a small crack, and now today another one. They have not run cracks across the windshield, but they could. So my question is this. Is there some kind if reflector that maybe directs the wind differently that maybe could reflect the stones? Or maybe some kind of coating that could help protect the glass? I think my insurance allows for glass breakage only once every six months. This some issue is getting out of hand.
  2. alekska
    alekska Active Member
    435
    138
    Atl
    What kind of road did you drive on when stone hit you? Where there any cars ahead of you?
    Alex
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Most deflectors don't work on large stones, just the small stuff. I'm not going to comment on my experience, as that would be tempting fate!
    48,987
    haven't read a lot of complaints here in 10 years.
  5. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    I try to avoid following large trucks and vehicles, and when I do, I try to leave more following distance. Already replaced the windshield once, out of pocket, for $400.
    SCH-I535
  6. Mendel Leisk
    38,247
    ^ +1 on increasing following distance. Obviously you can still catch a rock, but hang back further will help a lot.
  7. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    Highways the whole way to work. It's tough to be far behind everyone all the time. I was just wondering if anything was out there protection wise. Thanks for all the imput
  8. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    A lower deductible? A less rocky route?
    #8 Yakoma, Dec 16, 2014
  9. xliderider
    7,848
    3,102
    Honolulu, HI
    There's another area that a rock can do expensive damage to. Some people have had a rock damage the inverter coolant radiator behind the top grille openings. Once the coolant is lost, the inverter can quickly overheat and shutdown. If the inverter is irreversibly damaged, it's a multi thousand dollar repair if done by the dealer.
    I've put wire mesh screen behind both the top and bottom grill openings to keep out larger rocks that can fit through the openings. The smaller stuff that can get through the holes in the mesh hopefully can't do enough damage.
  10. David Beale
    5,963
    1,981
    Edmonton Alberta
    Well, there is a windshield plastic protector you can have applied. Just like the 3M vinyl tape stuff. It will help with the medium sized stones, but really large ones not so much. It will scratch easier than the glass too. If you have the special glass on your car it will make that not work.
    My experience has been the windshield is sloped enough most projectiles just bounce over the roof without any more than a tiny pit. Unlike the FJ Cruiser. It cracks in fear just seeing stones on the ground. ;)
  11. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    I haven't had any rocks hit my liftback yet *knock on wood*, but on my prius c I drove before it, I did have some paint chips on the hood, though luckily nothing happened to the windshield. The Honda Civic I drove before the c definitely sustained a crack in the windshield, but fortunately it never grew larger even after years of driving with that crack in it.
    Unfortunately part of the freeway I take to work is undergoing construction right now, so there's a lot of dump trucks on the roads. I've been either keeping my distance from them if I can see them well in advance, or if they're merging near me I drive a little faster to get in front of them so as to not be stuck behind them at such a close range. I figure burning a little gas is cheaper than fixing paint chips or windshield cracks.
