Fluctuating A/C Temp
Discussion in 'Prius c Main Forum' started by Carrion, Jul 30, 2020.
  1. Carrion
    Carrion New Member
    San Juan
    2014 Prius c
    For the first time I rotate the temp dial of the a/c. From then on I temperature change from heat to cool without changing the dial again.
    I turned on/off but still had the problem. What could be?
    51,140
    welcome!
    it is probably trying to keep a constant interior temperature
  3. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    Are you using ECO mode? When driving with ECO mode on, the car will turn the AC off temporarily whenever it needs more power, such as under heavy acceleration. But it should turn back on as soon as you lift your foot up a bit on the gas pedal.
