Fluid leak inside car near brake pedal
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by CMMVash, Aug 12, 2018.
  1. CMMVash
    CMMVash New Member
    Vashon
    2014 Prius c
    Hoping this is a simple fix and fully covered at 39k. I don’t think I’ve ever had fluid leak inside one of my cars before.
  2. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    Maybe something on your shoe? Or can you reach up and see where it's coming from? What kind of fluid?
  3. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Has the car being worked on recently in a dealership, and the guys over there, just forgot to cleanup their safety boots?
    49,507
    clogged a/c drain?
  5. Mendel Leisk
    38,735
    CMMVash and Raytheeagle like this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    There is a TIME limit on your warranty too.
    3 years I think.
    You probably are way over that.
    Two most likely causes are: Plugged A/C drain or a leak in the heater core.......neither of which most people can fix themselves.
    Edit: That really looks like OIL. Regardless, you need to get it checked out.
    CMMVash likes this.
  7. CMMVash
    CMMVash New Member
    Vashon
    2014 Prius c
    It’s at dealership now. We will see what they say. It’s had all of the service at his dealership. Only 39,000 miles.
    It’s definitely a drip inside the car. Not something I spilled or dropped.
  8. CMMVash
    CMMVash New Member
    Vashon
    2014 Prius c
    Guessing that would look more like water.
    Not from my shoes. It’s an oily tacky small drip. Will see what they tel me shortly.
    Are you all ready for this???!?
    Apparently a DayQuil liquid capsule fell behind the dash at some point. It melted? In the recent summer heat. They cleaned it up. $143
    #8 CMMVash, Aug 13, 2018
    Raytheeagle, bisco and Mendel Leisk like this.
  9. CMMVash
    CMMVash New Member
    Vashon
    2014 Prius c
    Seriously? DayQuil liquid cap. I can’t believe this was the answer. But somehow more believable than a serious problem with a car so young.
    Raytheeagle and ztanos like this.
  10. bisco
    49,507
    well, you're much more fortunate than the poster who needed a whole new brake actuator on a 2014.
    CMMVash likes this.
