flutter sound at part-throttle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ace., Nov 29, 2012.
  1. ace.
    ace. New Member
    Hello All,
    I recently bought a used 05' prius, and discovered a flutter sound (sounds like uneven tire) while on a smooth road. It comes from the engine compartment. I has no clue what IT can be.
    Below is a video of the sound
  2. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Sorry I can't hear any abnormal sound.
  3. ace.
    ace. New Member
    I recommend to turn your sound up. The abnormal sound is from 0 to 3 seconds in. then I speed up and it gets faint, and faster frequency
  4. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I hear the sound you are talking about, but I don't think you have a problem. The Prius makes all sort's of funny sounds, yours sounds normal to me. Believe me when I say this, the Prius is unlike any other car out there. It has it's own traits and it's own sounds. It takes a while to get used to it. Enjoy the mileage and keep smiling.
    Ron
  5. Patrick Wong
    18,200
    6,493
    I suggest you rotate tires, front to rear, and see if the sound moves. If it does that will prove your theory about a tire causing the sound.
    [email protected] likes this.
