FM Radio Problem
Discussion in 'Gen 2 Prius Main Forum' started by Dave of Woodstock, Mar 5, 2008.
  1. Dave of Woodstock
    Dave of Woodstock Junior Member
    Vermont
    I have had a very annoying problem with my 2007 Prius radio. I listen only to FM, and there are many FM stations in my area, but NONE of them come in clearly in my Prius. I have the premium JBL radio, the FM stations sound great in my other 2 vehicles, but they are unlistenable in my Prius. CDs in the Prius JBL radio sound great, so it is not the amp or speakers. The dealer has swapped out the radio, but no improvement. He says all Prius radios are the same. Could it be?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    No, the FM reception is okay. Have your dealer check the antenna and antenna lead.
    Tom
  3. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Revisit your dealer and have him let you try the radio in on an identical car to compare.
  4. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    I agree that sounds like a faulty antenna, cable or connections, or the FM radio is just faulty.
  5. Doc Willie
    1,717
    142
    Out there, somewhere
    The FM reception in the Prius is the worst of any car I have ever owned. I use my iPod a lot more now.
  6. qbee42
    18,058
    3,074
    Northern Michigan
    Mine works fine.
    Tom
  7. Qlara
    Qlara New Member
    488
    The Prius radio is using digital-tune. Can't you try to manually tune one of the FM stations frequency you familiar with and see how it sounds?
    Below the touch screen display, the radio has 2 circle turn-nods.
    The one on right-hand side can be used to tune radio station manually. Avoid using the Seek function on the radio if too much interference presents.
