Foam block canoe carrier
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Seayacker, Aug 6, 2013.
  1. Seayacker
    Seayacker New Member
    Just purchased a 2012 Prius Three with sunroof and wondering if we can use thule foam blocks to carry our canoe until our thule rack system arrives?
  2. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    No, to put it bluntly. Neither glass nor metal would on the roof itself would be a good idea. You don't want to put weight on part of the car that wasn't ever intended to support it.
    The side rails (the edges above the door) where the rack will attach is required. You'll have to wait until it arrives.
  3. HprDad
    HprDad Junior Member
    72
    17
    WI
    I personally wouldn't use foam blocks even on a steel roof, unless you're going a very short distance, at slow speeds. Wait for the Thule! I've used a Thule to carry a canoe for nearly 20 years, and would take it cross country. I use foam blocks only for a few miles to the local river, on my old civic.
