Foam that goes under center armrest fabric?
Discussion in 'Gen 2 Prius Main Forum' started by DonE, Mar 19, 2021.
  1. DonE
    DonE New Member
    Baltimore
    I'm a new account holder, but have benefited for years from the content on this site. Thank you all so much.
    I have just removed the console lid from my Gen2 prius to clean and re-affix the fabric, which was filthy and was entirely loose at the edges (as is typical after many years of use). The fabric is cleaning up well, but I was surprised to see the terrible state of the foam underneath the fabric. I'd like to replace it, which I suppose means buying some sort of foam sheet, using a spray adhesive, and cutting it around the edges to fit. However, I have no idea what specs exist for foam padding ... Thickness? Firmness?
    Has anyone replaced the foam who has the specs and/or a recommendation on a supplier/manufacturer?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  3. audiodave
    audiodave Active Member
    800
    272
    US
    It's like a 1/8 inch weak foam originally. Practically nothing. Go to a upholstery shop and find a 1/2 thick dense foam or least quarter inch to replace it. I don't think you'll be able to make the original fabric work with thicker foam. See if the shop has a remnant piece that kinda matches or you like and recover it.
  4. DonE
    DonE New Member
    Baltimore
    Thanks - I really appreciate the advice regarding getting new fabric and using a thicker foam. I went to a lot of trouble to get the original fabric perfectly clean (I tried many things - what worked in the end was entirely removing the fabric, soaking it in Whip-It for a few minutes, then rinsing and wringing it out in the sink, then laying out to air dry. I’m eager to attach it so it’s like new with this same (now cleaned) original fabric, and the only thing I need is a foam similar to the original foam.
  5. audiodave
    800
    272
    US
    You get the arm rest done?
  6. DonE
    DonE New Member
    Baltimore
    Yes! Thank you all so much. I ended up ordering "Sponge Neoprene W/Adhesive 12in Wide X 1/8in Thick X 54in Long" on Amazon, cutting it to fit, and attaching it with Shoe Goo. It came out looking and feeling like new!
    audiodave and SFO like this.
