Fob battery
Discussion in 'Gen 4 Prius Technical Discussion' started by CooCooCaChoo, Jun 4, 2018.
  1. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    So its been a year since I purchased my Two Eco. Having read that the fob battery should be replaced in a timely manner, i.e. before it dies and leaves you stranded, I went ahead and changed them out today. Pretty simple so I won't go into the procedure, but the interesting bits are as follows:
    Primary fob was down to 3.08 volts after 1 year of daily use.
    Secondary fob was down to 3.07 volts after 1 year of never being used. Obviously this fob was never put into power saving mode (turning off SKS).
    Brand new lithium 2032 battery read 3.28 volts out of the package for both.
    So down, probably 0.2 volts from brand new. The interesting thing for the next year would be to note how much turning off SKS on the secondary fob would save the battery.
    RCO and steuermann like this.
  2. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    IIRC, I think SKS turns itself off after a while if not used and the fob is more than 6 feet from the car (or in a faraday pouch).
    RCO, bisco and krmcg like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    When I got Samantha, I hid away one of her FOBS, sans battery. Just last week, almost 2 yrs old, I took battery out of the one I had been using, hid it away instead and re-started the "spare" as my normal use FOB. The used battery was only marginally lower than the unused one - I didn't record the figures - but both were still well in the "GOOD" zone on my tester.
    I've done this with my last 3 cars too - when I sell them at 3-4 yrs, they've still had the original batteries.
    RCO, kithmo and bisco like this.
    49,520
    a dead fob will not leave you stranded, just hold it up to the power button as you push it.
    i have a 10 year old cr2032 in a spare garage door opener that reads 3.29 volts. i was shocked.
    i don't replace the batteries until they die, so as not to hate batteries.
    Mendel Leisk, kithmo and alanclarkeau like this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    And the Gen 4 gives you plenty of warning on the MFD when the battery is low (apparently, as mine haven't run down yet).
  6. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Good thing the CR2032 has no lethal voltage, then! :eek::confused:
    Prodigyplace and bisco like this.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    You must be very sensitive to electricity :LOL:
  8. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    ...and use the mechanical key to lock/unlock the doors.
  9. Mendel Leisk
    38,751
    I think you'd get a warning on the dash, well before the fob battery dies. I took a quick look in the 4th gen manual, didn't see anything stating that, but that's how it is on our 3rd gen.
    I actually just got that warning the other day, it's been probably close to 3 years. When I get the warning for one fob, I replace the batteries on both.
    krmcg likes this.
