Fob Failure to Open Vehicle
Discussion in 'Gen 2 Prius Main Forum' started by skruse, Sep 9, 2008.
  1. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I rode in the 2008 High Sierra Fall Century Bicycle ride on Saturday, 6 September. I drove over the Sierra Nevada to south of Mammoth Lakes. I slept outside, but next to the Prius. When I awoke at 6:00 a.m. the FOB would not open the vehicle (it was not the FOB battery). I walked away from the vehicle, then returned - still no reaction. I tried every door. Finally, the vehicle opened by touching the rear hatchback. Strange. I have never experienced this before. Vehicle is performing well with excellent fuel economy. Does spending too much time close to the vehicle put the bluetooth in suspension?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The fob is in no way related to the Bluetooth system.
    When you say that the fob would not open the vehicle, do you mean that pressing the unlock button of the fob failed to unlock the car or that the door would not open when you touched the inside of the front handle?
    Tom
  3. Patrick Wong
    18,200
    6,479
    If the SmartKey fob is stored adjacent to the vehicle, then after a while the SmartKey system will turn off to reduce 12V battery drain. When that happens, use the fob button to unlock the vehicle.
    Also don't forget the mechanical key hidden in the fob, which you can use as a last resort to open the driver's door.
  4. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    And to clarify Tom's statement about bluetooth, since you may scratch your head: "bluetooth" refers to the RF system that allows your phone to connect to your car. The smart key is not bluetooth. So your fob is related to smart key, but not bluetooth.
    And PW, since you seem to know: you say SKS will turn off to reduce 12v drain. But does that mean you have to toggle the switch under the dash to get it back on?
  5. Patrick Wong
    18,200
    6,479
    I believe that SmartKey will automatically resume its operation if a fob button is pressed. If not, then pressing the dash switch should turn it back on.
  6. qbee42
    18,058
    3,074
    Northern Michigan
    My understanding was that it automatically turns back on, but I haven't tried this to verify it.
    Tom
  7. paco-shalom
    paco-shalom Veteran Prius Owner
    62
    Phoenix
    This is great info. I have also noticed that certain other electronic devices in close proximity to the FOB can interfere with the SmartKey operation.
    For example, when my phone (PocketPC) is in the same pocket with my FOB, the SmartKey system will not work at all. As soon as I take the phone or the FOB out of the pocket, it works just fine.
    I have also noticed that when I drive rented Prii, I have to push the button on the FOB to open the car and insert the FOB into the slot to start the car - how quickly I have been spoiled with the convenience of SKS (the rental did not have SKS). :)
