Fob locking
Discussion in 'Gen 2 Prius Main Forum' started by Vanne, Aug 18, 2012.
  1. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    I just wonder why lock by fob and we pull handle on the driver side and front passenger can open the door ? It is default system or error ?
    49,622
    if i understand you correctly, it may be programming you can change yourself. check your owners manual.
  3. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    I just wonder why i can open the doors even I lock the dor by pressing handl lock button already ?
  4. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    The doors can be programmed to unlock in various ways. That is why Bisco suggested you consult the owner's manual. It appears to me that your car's programming has been adjusted whereas all the doors will unlock, which is a feature that Prius offers. Again, consult your owner's manual for more information.
    Here is the info that is online at Toyota's website. Refer to page #31 for the details on how the doors can be programmed.
    http://www.toyota.com/t3Portal/document/om/OM47509U/pdf/2-1.pdf
    Ron
