FOB Not Working & P0A1D, U0100, U0293
Discussion in 'Gen 2 Prius Main Forum' started by Tony Lucas, Oct 24, 2018.
  1. Tony Lucas
    Tony Lucas Junior Member
    26
    Louisville
    Hellow Prius Friends. I've seen and fixed most of the Prius codes - but this is a new one. Nothing seems really wrong with the car, except I can't start the car with the push button. I have to put the FOB in the slot by the steering wheel. These are the error codes on my App - P0A1D, U0100, U0293
    Any ideas?
    49,582
    fob battery? 12v?
    Tony Lucas likes this.
  3. Tony Lucas
    26
    Louisville
    The 12V could be the issue? So, look at the 12v and then re-read the codes? Should I re-charge the 12v?
    49,582
    how old is it? test it in the morning with a volt meter, then charge it if it is below 12.5
    if it won't hold, replace it
  5. Tony Lucas
    26
    Louisville
    The car is 2006. The 12v is at least 5 years old. I'll recharge it. I tried looking at old posts - some talked about a computer, but there are so many computers on the car, I didn't know what to go after.
  6. bisco
    49,582
    low hanging fruit. if it is not the 12v or fob battery, you will have to look up the codes in the service manual.
  7. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Do you have the associated INF(s) or subcode(s) for that thrown DTC P0A1D, there are over 20 INF's for this DTC.
    Knowing which INF (subcode) can help efficiently track down a problem. You may need access to a compatible OBD2 device to retrieve such.
    Here is the work up for DTC U0100 and DTC U0293:
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/20zmw/ciu0100.pdf
    Tony Lucas and Raytheeagle like this.
  8. Tony Lucas
    26
    Louisville
    I have Toyota Techstream on my computer, I'm assuming that will show an INF Subcode.
    What would be an example of the INF Subcode?
  9. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Yes, techstream will work perfectly. INFs (subcodes) follow a three digit format, like "143".
    Check in the scan results for an flower like icon between the 'Monitor Status' and the 'DTC' columns, click it.
    Below is an image with a DTC (P312F) circled in red, to the left of that is the icon you're looking for.
    Skibob likes this.
