FOB vs. KEY
Discussion in 'Gen 2 Prius Main Forum' started by Stan Wilson, Mar 7, 2004.
  1. Stan Wilson
    Stan Wilson New Member
    53
    Can one take the tiny key out of the fob and place it on a separate keyring to prevent lockout or will the transponder fob not work without the little microkey in it?
    Picked up my white Prius Saturday and have played with it all weekend.
  2. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    The Prius won't let you lock the Fob in the Car if that's what you're worried about, at least not with Smart Start/Entry
  3. rockluvr
    rockluvr New Member
    155
    Denver, Colorado
    You CAN lock the fob in the car if it is not in the ignition if you don't have smart entry/smart start. If the key is in the ignition, then no.
  4. Stan Wilson
    53
    I guess what I am asking is: can I keep the little metal mechanical key separate from the rest of the fob...will the fob transponder still work to run the car. I don't have smart anything.
  5. xlarimer
    xlarimer New Member
    135
    berkeley, california
    Then you won't have a hole to hang off your key ring! :)
    I replaced my SE/SS key ring with a better/larger key ring so I can hang it in the key box when I get home. (Or else I lose my keys.) I was rather taken back at the low quality hardware that was hanging off of an otherwise beautiful (Johnson Controls, Inc.) technology.
    Haven't tried to start it via valet with the small key not in it. Will have to try though. I still think that having a gaping hole there will just mean it will fill up with pocket lint and strange things I'd rather not think about. It is probably best to just have the key there and get a secondary wallet/pocket key to hide somewhere instead.
    xo
  6. rockluvr
    rockluvr New Member
    155
    Denver, Colorado
    Stan,
    Just for you, I went out with the fob, but without the door key attached to the fob and started the car. Yes, it starts without the key. Putting a key ring on the fob other than on the small door key so that you could put the key elsewhere for an emergency would have been nice. Oh well.
  7. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    I just went to my local locksmith and made copies of the key to scatter around purse, hubby, etc. instead of taking out the original and loosing the keychain part. $2 each....
