FOB works but not transmitting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mario17, Mar 18, 2016.
Tags:
  1. Mario17
    Mario17 New Member
    San Francisco
    all
    One of my FOB partially stopped working, so I can't use all 3 keys on it.
    at the same time my Prius senses it, I can start car when I have it (either inserted or in pocket).
    I still can lock car by pushing outside key on door handle, I still can open trunk on closed car.
    So I think problem isolated just to those keys operations, something got broken.
    I read all horror stories about getting new one, so maybe somebody can share his/her knowledge how to fix or replace maybe some part of fob circuit.
    I still have second FOB key which works OK
    ** and surely enough all tested on new battery.
    Thanks all
    mario
  2. Augustus88
    Augustus88 Junior Member
    87
    29
    Birmingham, AL
    Three Touring
    Smart key functions still work, but the lock, unlock, and panic buttons on the fob do not work?
    I believe the smart key functionality is controlled by a separate small black box that is inside the key and does not require a battery to work. Someone correct me if I am wrong...
    If the above is true, then most likely the circuit board inside your fob has failed, as it is not required for Smart key functionality.
  3. JC91006
    16,673
    8,518
    There's a stuck button. 1 of the 3 buttons on there is stuck, use a sharp exacto knife and prey it free
    usnavystgc likes this.
  4. Mario17
    Mario17 New Member
    San Francisco
    No stuck buttons, no physically all clicked, also tested with second remote.
  5. JC91006
    16,673
    8,518
    If you are certain there are no stuck keys and you've tried a new battery, then you have something wrong with your FOB
  6. Mario17
    Mario17 New Member
    San Francisco
    yes, I thought I can change just some piece of fob , it's transmitter part, and keep all crypt stuff as is.
    @JC, you prius history is very impressive!!!
    2015 Prius Plug in base
    2015 Prius Two
    2010 Prius V
    2008 Prius II
    2006 Prius III
    2005 Prius V
  7. JC91006
    16,673
    8,518
    That's not history, that's current.
  8. bisco
    51,148
    have you looked at the circuit board, and the switches under the keys?
  9. laroleta
    laroleta New Member
    bisco, I have a similar problem with a lock button that does not register. Any tips on what to look for on the circuit board and switches?
    The previous owner broke the rubber button cover so the lock button switch and a portion of the top circuit board is exposed (probably what caused the issue in the first place)
    Thanks
  10. bisco
    51,148
    i think your best bet is to find a replacement on ebay and swap the guts. do you have a second fob?
