Fob
Discussion in 'Gen 2 Prius Audio and Electronics' started by john edon, May 14, 2015.
  1. john edon
    john edon New Member
    Barnsley
    Is there any way to enter prius when the car is locked and alarmed
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Trying to steal one?
  3. john edon
    Barnsley
    The battery went in fob but I had spare battery so every thing was ok but what if I had not is there any way to enter the key works when just locked but not when alarmed
  4. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Are you talking about the built-in immobilizer or an aftermarket alarm system?
    If the immobilizer, use the key to unlock the door, then place the Toyota symbol on the fob against the power button for a few seconds - then press the power button to start the car. It's in the manual.
    If it's an aftermarket alarm system, all bets are off.
  5. john edon
    Barnsley
    The small key works when the car is just locked but not when locked and alarmed
  6. bisco
    49,492
    then it must be an aftermarket alarm, so i think you're out of luck. when you say it doesn't work, you mean the door opens, but the alarm goes off.
  7. john edon
    Barnsley
    No the door will not open when you press the fob twice only when you press once
