Fog adjustment
Discussion in 'Gen 2 Prius Main Forum' started by ammiels, Apr 29, 2005.
  1. ammiels
    ammiels New Member
    121
    brewster, ny
    Does anybody know if it is possible to adjust the fog lights? I would like them just a little tad higher.
  2. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    I don't think there is any way to adjust the fog, that's just a factor of nature. Maybe a really big fan might blow it away.
    Oh, sorry, was going by the post title. After reading your post, you meant the fog LIGHTS! :)
    Yes, there is an adjustment screw behind the adjustment hole underneath the car. I may have posted a diagram or at least the repair manual text on it somewhere.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yeah those factory "fog" lights have really poor beam pattern and reach. They're decorative only, not functional.
  4. bobc
    bobc New Member
    361
    Durham, NH
    Yep, as Danman mentions, there are adjustment screws on them. You can get at them by just dropping the the plastic pieces underneath the fender corners. These pieces are also the wheel wells but you don't have to take them completely off. You'll just need a 10mm socket and a flat headed screw driver to pop out the plastic grommets.
    In the photo, you can see the adjustment gear. Can't remember if it takes a Phillip's head screwdriver or not....
  5. ammiels
    ammiels New Member
    121
    brewster, ny
    Thanks. Next warm dry day and clear night.
