Fog light adjustments
Discussion in 'Gen 3 Prius Technical Discussion' started by PutPutMobile, Mar 4, 2018.
  1. PutPutMobile
    PutPutMobile Senior Member
    292
    518
    Buena Park, CA
    I’ve seen the adjustment module wheel for the fog lights. Since I don’t have the right tools for a bigger jack to hold the car, I asked a shop who installed my fogs to adjust it. They said they adjusted the fogs the lowest level they can and won’t turn anymore. It’s still aiming higher than my led lights.
    Anyone have problems with these settings? Or I might have someone reinstall it again so it will be in the correct level. I don’t want to use it right now cos I might blind someone in front of me.
    Need help please. If somebody knows a shop in Orange County who can adjust it the right the way, let me know.
    18CB8104-E6A7-40C8-B6FE-6E14C20397FC.jpeg 9761217A-CC90-4160-9C4D-3A39FE728472.jpeg
  2. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    If you bought the reflector based oem style foglights, they have a lot of glare (stray light), as you've discovered.
    What you want is a projector type foglight that has a cutoff shield like the lowbeam headlights on cars equipped with halogen projectors.
    Danny3xd likes this.
  3. xliderider
    8,055
    3,222
    Honolulu, HI
    ReDave likes this.
  4. PutPutMobile
    292
    518
    Buena Park, CA
    Whoa thanks. It sucks though I barely bought these fogs.
  5. PutPutMobile
    292
    518
    Buena Park, CA
    Does it matter if I got LED bulbs with it?
  6. xliderider
    8,055
    3,222
    Honolulu, HI
    Not really, the reflector foglights don't have any cutoffs, so that's the problem.
  7. xliderider
    8,055
    3,222
    Honolulu, HI
  8. PutPutMobile
    292
    518
    Buena Park, CA
    Oh man. I gotta buy another set.? Lol. Oh well.
  9. xliderider
    8,055
    3,222
    Honolulu, HI
    I always suggest buying the cheapest set of oem style foglights which go for about $40, just to get the shrouds, wiring harness, and dashboard switch. Then get the projector foglights and swap out the crappy reflector foglights.
  10. PutPutMobile
    292
    518
    Buena Park, CA
    I don’t know if these fog lights can still sell. I’ll get them projector lights soon. Maybe I can install them myself since it’s just bolt on.
  11. PutPutMobile
    292
    518
    Buena Park, CA
    Hmmm. Maybe the fog lights are switched. I might take it out and switch them. I haven’t seen fogs that are centered before.
  12. xliderider
    8,055
    3,222
    Honolulu, HI
    No, it's not possible to switch them left to right, the mounting tabs are offset quite a bit.
  13. xliderider
    8,055
    3,222
    Honolulu, HI
    FYI, here's a comparison of a projector foglight with an oem style foglight:
    PutPutMobile likes this.
  14. PutPutMobile
    292
    518
    Buena Park, CA
    Ohhh I see the difference
