fog light cover cracked
Discussion in 'Gen 2 Prius Accessories & Modifications' started by arvind, May 2, 2009.
  1. arvind
    arvind ape
    san francisco
    Hi
    I noticed that my fog light was out... took the car into magnussens toyota in palo alto and they told me that I needed to change the entire assembly. It would cost me about 120 dollars. I opted just to replace the bulb instead and figure out how to patch the half centimeter long crack. THey told me that moisture etc can cause the bulb to burn out.
    Does anyone know of a clear epoxy or anything that I can apply over the fog light cover that is heat resistant enough? I looked for just the fog light cover online and could not find any...
    Any ideas?
    thank you!
  2. Dobey
    Dobey New Member
    Couldn't you just make your own cover? Take the old one out, get some thin plexiglass, cut it to the appropriate diameter and affix to the existing fog light dome using a high temp epoxy like J-B Weld...
    Or go to a junkyard and look for a used Prius fog light assembly...
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    I would try to repair the lens crack with something like this:
    IPS Weld-On 16 Cement: TAP Plastics
    You should have a Tap Plastics somewhere nearby. You could also check out the local hardware store or Home Depot for similar plastic adhesives. You want something that will dry clear.
