Fog lights all the time?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by glennonrp, Mar 13, 2016.
  1. glennonrp
    glennonrp Active Member
    178
    199
    Fontana, CA
    Four Touring
    This is probably a dumb question. I won't let that stop me, though.
    Is there any reason(s) not to run my fog lights all the time? They only come on when the headlights do, so it wouldn't be ALL the time. But, I like the way it looks, both looking at the car, and when driving, with them on.
    I'm unable to think of any reasons. But, this is the first time I ever had fog lights on a car.
    If this is the wrong place to ask, please let me know.
    SilverStreakR and dziadek1818 like this.
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Your 2013 Prius has daytime running lights, so using fog lights all the time is redundant and it loads the electrical system a bit more. Your fog lights wear out quicker too.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    If you're in Australia - it's an offense. I think the fine is about $120.
    The other thing is, they're annoying other drivers, particularly on wet roads. Instead of seeing just 2 headlights, plus 2 reflections off the wet road, there will be 4 lights plus 4 reflections - and if DRLs are on as well, it's just annoying.
    SilverStreakR likes this.
  4. sttkailua
    sttkailua Active Member
    190
    151
    Hawaii
    I don't see any problem using fogs as DRL.
    It depends if the police in your area harass drivers for this.
    They don't in my area.
    You just need to connect the fog relay
    To the other DRL circuit.
    I have 2016 4 without any fog lights, so I need to add it in as an after market.
  5. dziadek1818
    dziadek1818 Junior Member
    28
    poland
    No problem driving with them on in Poland.
    actually i want to install them on my prius two version
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    DRLs are all very well. although they tend to dilute any benefits of motorcyclists running with their headlights on all the time. I turn my headlights on whenever they're needed for me to see, or be seen! What I find annoying is folk who park their car, and leave their lights on! OK, I realise they turn off automatically, but only after they've succeeded in blinding me (whether I'm walking or cycling or driving). My rule is car stopped == headlights off! I like having total control of all the features I consider to be important. :rolleyes:
  7. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Alright, alright - we get it! :D
    kithmo, WilDavis and dziadek1818 like this.
  8. WilDavis
    2,493
    2,155
    49
    Get it? Got it? GOOD! :rolleyes:;)
    kithmo, RCO and RRxing like this.
  9. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    I had the same idea, because I also like the look, and I don't think they are so bright or pointed in such a way that they will blind another driver, but at first I did not realize that they will turn off whenever the high beam lights turn on. At one point, I was using the fog lights as well as the automatic high beams, and I would often see the high beams coming on for a moment then switch off, only to come on again a moment later. I can't help but think so much switching cannot be good for the electronics and bulbs of the fog lights. Perhaps the high beam lights are better engineered for frequent switching. The bottom line is: I've decided to not use the fog lights when I'm on a highway where the high beams may be switching off and on frequently, but I will continue to use the fog lights around town, where I don't usually need high beams. In fact, I've pretty much decided to stop using the automatic high beams period. It just seems the technology has not developed sufficiently to always make the correct decision about when to turn the high beams on and when to turn them off.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Hmm. They're actually LEDs in UK and not incandescent bulbs.
  11. davecook89t
    1,092
    826
    Four Touring
    So no harm from frequent switching then? I guess I don't know enough about LEDs.
    RCO likes this.
  12. Quentin
    Quentin Member
    335
    West Virginia
    Don’t drive with your fog lights on unless you are driving low speeds because of fog. The reason is that you should be looking down the road rather than immediately in front of your bumper. Your eyes adjust to the most prominent light. If your fog lights are on, the most prominent light is just in front of your bumper rather than further down the road. You want to see things as soon as possible so you want obstacles to appear as far away from you as possible so you have maximum reaction time.
    iPhone ?
    kithmo, qettyz and RCO like this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Logical, Captain!
