Fog Lights on a Base PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by grodnyc, Jan 11, 2013.
  1. grodnyc
    grodnyc Junior Member
    24
    Long Island, NY
    Has anyone installed fog lights on a base PiP? Is it feasible?
    I might be interested on getting one installed with yellow bulbs since they are great for rain.
    Any help is appreciated.
    Thanks
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    It's a pretty complicated install on 2012 Prius if you want the factory look since Toyota moved the foglight location from the integrated turn signals to lower grill. You'd need a need a lower grill plastic shroud from a PiPA or a Prius 5. This guy has some fantastic DIY's on a lot of Gen 3 Prius mods. He even found out that a Yaris OEM foglight kit comes with a button that fits perfectly in an empty accessory spot to the lower left of the steering wheel.
    DIY: How to add aftermarket OEM-style fog lights to a 2012 3rd gen Toyota Prius Two, Three or Four (non-Five models); complete retrofit installation guide with wiring diagram | Balancing Act
    lensovet and Sanjath like this.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    Interesting and excellent write up. Basically, you need a replacement grill ($102) with fog light hole/mounts, fog lights ($40-100) and the installation.
