Fog lights on advanced = useless
Discussion in 'Prime Main Forum (2017-2022)' started by Dmitriy Sokol, Feb 17, 2017.
  1. Dmitriy Sokol
    Dmitriy Sokol Active Member
    112
    108
    Annapolis, MD
    Am I the only one who finds fog lights on Advances to be no more than a cosmetic touch? Maybe it's just my Prime, but I don't see how they contribute to lighting the road. I can barely notice that they are on/off.
  2. mr88cet
    mr88cet Senior Member
    2,306
    1,331
    Austin, TX
    Have you had a chance to try them in actual fog?
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,023
    Westminster, Colorado
    I've never seen any fog lights that weren't useless.
  4. tf4624
    tf4624 Active Member
    526
    51
    I think they are LED. Suggest take them out and upgrade to 6k led or hid if you want them to be used like they were suppose to
  5. Tideland Prius
    16,125
    Story of the Prius. The Gen 2 are completely useless. The Gen 3 is almost useless (at least I can see it illuminate the curb).
    They're mostly cosmetic. My smart fortwo's foglights were pretty good.
  6. iamvietdang
    iamvietdang Member
    57
    60
    West Palm Beach
    Four Touring
    Definitely cosmetic. They barely light up the road 5' in front of the car.
    2016 Prius 4T Premium Convenience Pkg
    2016 NX200t F Sport
  7. mr88cet
    2,306
    1,331
    Austin, TX
    Interesting... Fog is not common here in Austin (TX), but on my Gen-2, I found them to help on the rare occasions that we do get fog.
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It's not just the Prius fog lamps. It's every car in North America. You see, by law or regulation, if the fog lamps are on the headlamps must also be on. So the headlamps are blasting right back at your eyes reflected by the fog and the fog lamps do you no good. Further, it has been known for at least 100 years that proper "fog lamps" are yellow. It penetrates the fog better. I guess we've forgotten that now.
    However, they do look cool. That's probably what they were -actually- intended for anyway. ;)
  9. Prius Maximus
    Prius Maximus Senior Member
    935
    780
    Northeastern IL
    Not sure about that law. My truck fog lamps can be on without the headlights. They actually help, but there is a bigger vertical separation between them and my sight line than in the Prius - or any sedan.
    More than the yellow color, the intent is to place the fog lamps below the fog layer to allow the light to shine down the road beneath the fog. Doesn't work well when the fog extends to the ground.
    xtins, dalcon95 and Dmitriy Sokol like this.
  10. Lee Jay
    5,850
    4,023
    I have a gen 2, and I've never really been able to tell if the fog lights are on or not.
  11. Mendel Leisk
    38,644
    Yeah our Canadian touring 3rd gen fog lights are pretty much useless too. As you say, you can hardly tell if they're off or on.
    Our daughter's Pilot's fog lights are much more effective, in comparison.
  12. iamvietdang
    iamvietdang Member
    57
    60
    West Palm Beach
    Four Touring
    The only lower lights I've ever found useful are the ones that light up the curbs and close surroundings when you turn in a parking lot or at low speeds like what we have on our NX.
    2016 NX200t F Sport
  13. Tideland Prius
    16,125
    I had it on during a fog episode in 2005. Made no difference.
    However, my Gen 3 is wired such that the fogs can be on with the parking lights (but the DRLs are still on). It worked a bit better in the blowing snow.
    The issue is the law that requires the low beams to be on when the foglights are on. The whole point of foglights is to illuminate from under the fog (that's why they're supposed to be mounted low on the vehicle. It's rare that fog will be so thick that it's 1" off the ground.... maybe in parts of the UK but rarely in North America AFAIK).
    The only way around that is if your vehicle uses the foglights as DRLs (but Canadian law requires them to be a bit higher up the bumper as they must be a certain height above the ground).
  14. fuzzy1
    10,150
    I agree for factory installed 'fog lights'. But the Honda accessory brochure add-ons (really Bosch Pilots) that I installed on my 1986 Accord were very useful, especially considering the awful headlights (standard singular rectangular USDOT-approved sealed beam of that era) that came on that car.
    I believe that problem here is that factory installed so-called 'fog lights' must be 50-state legal. Proper useful fog lights are (at most) 48-state legal.
  15. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    On my 2010, I can tell when they're on because the incandescent fog light is different color than led headlights. They really help when one of the headlight is broken, not my Prius but on my Sienna. Fog lights are supposed to be yellow to be effective.
  16. xtins
    xtins New Member
    26
    US
    It works for me, Long Island, NY. We get fog every year and they did worked for me, and I do notice when they're on or not. Prius Prime - Advance 2017.
  17. Mendel Leisk
    38,644
    Was this a third gen you have the most fog light experience with?
    Have to say, I've hardly driven ours in fog, especially dense fog, and it's typically on well lit streets anyway, so hard to tell.
  18. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    The mis-named fog lights are actually for lighting the sides of the road. The ones on my Prime do a little bit of that. Any of the so-called fog lights are a help on a dark wet or snowy road. None I've seen are any help in fog.
    Trollbait and fuzzy1 like this.
  19. Mendel Leisk
    38,644
    That's what I like them for. Those stretches of twisty road with no streetlights. They're not very good at that though.
    I'm assuming the prime fog lights are about the same as our 3rd gen.
  20. geguia
    geguia Active Member
    209
    108
    los angeles
    im waiting for some aftermarket side marker LEDS for us non advanced owners.
    I also don't care for the look of the fog lights.
