Fog switch
Discussion in 'Gen 2 Prius Main Forum' started by qmtran, Sep 23, 2009.
  1. qmtran
    qmtran Junior Member
    87
    Seattle, WA
    So does the 09 Prius come with a fog light switch(button) or is the switch located on the light stalk? I've tried searching but came up with useless info about not getting the factory fogs, hid upgrade, etc. Everything but the answer. I am planning on running Hella Micro DE fogs but am trying to make the wiring look stock. Any info would be great.
    Thanks.
  2. qmtran
    87
    Seattle, WA
    mm...no one with a fog light equipped Prius? 41 looks and no response?
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    It's on the same stalk as the headlight control.
  4. Patrick Wong
    18,210
    6,513
    ...and is a ring that rotates on that stalk.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    ...and it turns on a pair of decorative lights.
    Tom
  6. dogfriend
    7,512
    1,190
    Carmichael, CA
    That don't match the color of the HID headlights.
  7. Patrick Wong
    18,210
    6,513
    ...with zero utility.
  8. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    And won't turn on the fog lights without the headlights, so you still get the enhanced backscatter halo...
  9. qmtran
    87
    Seattle, WA
    Now how would a Halogen bulb suppose to match the color of a HID bulb? Common sense says they never will match.
  10. qmtran
    87
    Seattle, WA
    Thanks for the info. ;)
  11. qmtran
    87
    Seattle, WA
    In all US cars, this is the case. You cannot turn on the fogs without the headlights if the fogs are OEM stock. Research before trolling.
  12. qmtran
    87
    Seattle, WA
    Thanks for trolling and posting info that does not pertain to the question I asked.
  13. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    Re. Lax.
    Jokes concerning the utility (or lack thereof) of the fog lights are numerous.
    Your question had already been answered before the jokes began.
  14. qbee42
    18,058
    3,079
    Northern Michigan
    Wow. Someone's shorts are too tight. :D
    One of the common misconceptions from new posters is that a thread belongs to the OP. Eventually you realize that you may start a thread, but what happens after that is out of your control. Usually it's best to sit back and enjoy the ride.
    Tom
  15. dogfriend
    7,512
    1,190
    Carmichael, CA
    They are decorative lights, so they should match for best effect. :madgrin:
  16. qmtran
    87
    Seattle, WA
    No, jokes are fine. I have been on many forums. And mainly I view a forum as a source of information for DIYer's. But when you use the "Search" on this forum for anything regarding foglights, all you really get are bs comments about the nonfunctionality of the stock units. It becomes annoyingly redundant.
  17. qmtran
    87
    Seattle, WA
    Numerous they are. Posted all over this forum, they are. Thats why they are...not funny and are annoying. I think everyone understands the stock units are useless, so why press the issue unless you are only doing so to be seen/heard like a 5 year old child?
  18. dogfriend
    7,512
    1,190
    Carmichael, CA
    Did we mention that the stock foglights are woefully inadequate? :madgrin:
  19. qbee42
    18,058
    3,079
    Northern Michigan
    Not only that, but they don't work very well either.
    Tom
  20. qbee42
    18,058
    3,079
    Northern Michigan
    Come back and complain again after you have about 9,000 more postings. You can't imagine how many times we answer the same questions, explain the same concepts, and listen to the same gripes. It all comes with the territory. Joking is the only way to stay sane, and avoid taking pot shots at annoying posters.
    Tom
