Foot park brake or not - concerned about slight rocking after park button pushed and tranny damage
Discussion in 'Gen 2 Prius Main Forum' started by sas0611, Mar 28, 2008.
  1. sas0611
    sas0611 Member
    230
    I've only had my prius a week but I notice that after putting the car into park with only the park button, the car will often move forward or backward a few inches until the transmission locks against the pawl. Is this somewhat stressful / abrupt motion bad for the transmission. I am careful to let my foot off regular brake slowly after pressing the park button but is still settles in to position a bit harder than I think is
    I've never used the emergency park brake with any car unless it is manual transmission and really don't want to use it in my new prius. Inevitably in the beginning you forget to take it off and do some damage to your brakes.
    Are most of you disciplined to use the foot emergency brake in your prius ?
    Thanks in advance.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Re: Foot park brake or not - concerned about slight rocking after park button pushed and tranny dama
    You won't damage your brakes with the foot brake. Unlike most cars, it's pretty hard to drive away with the brake on. Mostly you sit there with a dumb look on your face, thinking "Why won't it move?"
    As for hurting the transmission, the Prius transmission is always engaged, so there is no issue about stripping gears or the like. What you feel, as you surmised, is the parking pawl coming into position. Ease your foot off the brake slowly and it will lessen the shock load on the parking pawl. Either way, it's pretty tough, so you don't need to worry about it. Besides, the ECU won't let you engage the parking pawl if the vehicle is moving too fast.
    Tom
  3. patsparks
    10,664
    567
    Adelaide South Australia
    My handbook says not to use the park brake in freezing conditions so the park pawl must be strong enough in Toyota's eyes to hold the car. They do however recommend chocking the wheel as a precaution.
    BTW it isn't an emergency brake, it is a parking brake. I wouldn't want to count on a parking brake in an emergency.
  4. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    As I found out :redface: the Prius will start beeping at you if you attempt to drive off with the parking brake on.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I don't think you will damage the "parking pawl" in the transmission. It's not a pawl from the pictures I've seen posted. It's a gear. The only sliding gear in the "transmission".
    I always use the "parking brake". It's never frozen or corroded on. I -have- tried to drive away with it engaged (only once so far), and it did complain loudly ("what IS Pearl upset about, why is she beeping at me?!"). To err is human. To correct your error before it results in bad things is smart. ;)
  6. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    Every automatic transmission vehicle I have ever driven has done that, some worse than others. When I was with the Utah Guard, their hummers would rock back and forth until you felt seasickness coming on. There is some serious drivetrain slop in those things!
  7. richard schumacher
    7,663
    1,038
    United States
    Ditto that! Safety calls for redundancy, so always use the parking brake.
  8. patsparks
    10,664
    567
    I've never had a parking brake sieze due to freezing but the handbook says it can happen.
  9. BlackPri08
    BlackPri08 New Member
    50
    central Indiana
    Setting the park brake also is how the rear "shoe" brakes are kept in adjustment, so it's a good idea to use it regularly.
  10. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    17
    So, you may as well chock your tires too. Everyone knows that triple redundancy is even safer. :rolleyes:
    I NEVER hit the parking brake on flat ground. I also, to some, live dangerously by not hitting the 'park' button prior to powering the Prius off. ;)
    I will gladly take the added 0.0000001% risk that my car will spontaneously roll away on flat ground after the parking pawl breaks if it means I can make a quicker getaway for the 0.00001% chance that a carjacker is approaching my vehicle just after I park.
    . . . Or maybe the 0.000003% chance that I see an airplane falling out of the sky and coming right at me in my parked car.
    . . . Or maybe the 0.000006% chance that _ _ _ _ _. ;)
  11. patsparks
    10,664
    567
    A lot of Patricks in this forum and some are smarties aren't they?
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Yes my 07 does that exact same thing too...the clunking around when it parks. You'll get used to it quite quickly. Its normal don't worry about it. I always engage the parking brake every single time so its now muscle memory which is what I want so I never forget to engage it. Especially when I really needed to.
  13. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Contrary to popular belief, automatic transmission cars are not designed to be parked without the parking brake engaged.
    You should ALWAYS use the parking brake when parking. ALWAYS. In most states its actually the law also.
  14. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I have always, for decades, applied the parking brake first then put my transmission into park. With my Prius, it's parking brake first, then off.
  15. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Although technically true, this is rarely enforced unless the car has run away. Michigan allowed substitution of the "park" setting in 2003 after a cop ticketed a bunch of parked vehicles that didn't have the brake set. (link) A lot of these laws predate automatics -- MN's dates to 1937.
    In my home state of Arizona it's not required. Interestingly enough, the law seems to prohibit curbing your wheels (turning them into the curb to brace the car):
    I put the brake on if I'm on an incline, otherwise I don't bother.
    The 2007 Prius manual doesn't mention anything about the parking brake when it discusses going into park. The separate section about the parking brake says it should be used to "avoid inadvertent creeping".
  16. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    After the looks my wife gave me in the past when the car rocked as she was getting out of the passenger side, I've always set the parking brake before I open my door.
  17. novice
    novice New Member
    Los Angeles
    Is it necessary to push "P" button before turning off the car? Sometimes I forget to put it into park, but "P" lights up for a second before everything switches off, anyway.
  18. David Beale
    5,963
    1,981
    Edmonton Alberta
    Old topic, but as you're a newbe, the Prius goes into "Park" automatically when you turn it off. Note that this can be a problem if you, for some reason, want to leave it in "N". You can't.
  19. patsparks
    10,664
    567
    You can put the Prius in neutral with the HSD off by pressing the power button twice from off with your foot off the brake to go into accessory mode. In this mode you can select neutral but it will go into park when you turn it off.
    If you are concerned about the rocking in park, allay your concerns by engaging the park brake before switching off.
  20. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    When I street-park my Prius in the city, I always set the parking brake.
    New Yorkers are notorious for trying to shoehorn their cars into really tight parking spaces on the curb with lots of back-and-forth maneuvering. And in the process, the car being shoehorned is going to hit the bumper of the adjacent cars, sometimes pretty hard.
    Setting the parking brake in such situations sounds like a good precaution to me... As well as having bump strips on the bumpers (which I have). :cool:
