Foot Rest (dead pedal)
Discussion in 'Prius c Accessories and Modifications' started by tk1971, Aug 2, 2012.
  1. tk1971
    tk1971 Active Member
    253
    133
    SG Valley, CA
    All my previous cars had foot rests (aka dead pedal). Seems like a minor thing, but my Yaris didn't come with one either.
    Coming from Subarus, I know that they have flat foot rests that can fit any car. Got mine used off ebay ($9 shipped). Drilled 2 holes, and secured the pedal with 2 trim plugs.
    Danny13pruisc3 and Surrylic like this.
  2. ETC(SS)
    6,542
    Not bad at all....
    Sharp install!
  3. allopatry
    allopatry Junior Member
    69
    16
    Lake George, NY
    2023 Prius Prime
    SE
    Mine is not quite as sharp looking but functional. I still have about 85 percent of the floormat I cannibalized to create it in case I need to make replacements. Measured top to bottom and side to side: about 4" wide at the top, 5" wide in the middle and 6" at the bottom X 6" high. I bought a single floor mat and cut out a rectangle 6"x6' and then marked it and cut it. It is adhered with velcro tape and will keep the carpeting from being worn down by my foot. I can easily make others as needed from the $9.00 floormat.
  4. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Ouch I couldnt drill in my car like that
  5. Oatflake
    Oatflake Junior Member
    Glendale, CA
    2014 Prius c
    Sorry to reply so late to this thread - does anyone have any information about the Subaru dead pedal? The pictures are all showing as broken links and I'm looking at adding a dead pedal to my 2014 Prius C!
    Danny13pruisc3 likes this.
  6. Danny13pruisc3
    173
    27
    maryland
  7. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    I added a cheap aluminum dead pedal bought from AliExpress. haha.
    The dead pedal needs 4 screws to attach but after lifting the carpet near that area I found that it is styrofoam under the dead pedal position. So easy enough, make 4 holes in the carpet and attach the aluminum dead pedal with bolts, nuts and large washers. The remaining length of the bolts dig into the styrofoam and everything stays in place. Zero drilling into the car frame or floor.
