For people that talk about there being a "ghost in the machine"...
Discussion in 'Gen 2 Prius Main Forum' started by roverguy78, Mar 18, 2010.
  1. roverguy78
    roverguy78 Elite Lurking Member
    118
    24
    San Antonio, Texas
    A lot of people don't seem to realize that it is not possible on the Prius for the accelerator pedal to move all by itself. They seem to be thinking about cars that have a throttle cable. The only way the Prius pedal gets moved is by someone physically pushing it down.
    In many of these reports, it is stated or implied that the pedal took on a life of its own and moved all by itself to the floor and became stuck there. Then people blame the electronics. That is complete nonsense.
    The electronics can not physically move the pedal. If your pedal is to the floor, it got there from being pushed by your foot.
    A defective pedal could bind or not return fully. That is at least possible and rational. But, evil electronic "gremlins" do not have any direct control of your pedal. That is not possible on the Prius.
    If electronics were to blame in any of these incidents, the pedal would not have been physically moving by itself. It would have been at rest, and not stuck to the floor. For example, Sikes claimed that his pedal was stuck to the floor and couldn't be pulled back. That would have implied a stuck pedal... not rogue electronics, yet that is what many people still believe happened to him.
    I think it's time for a reality check and some common sense.
    5 people like this.
  2. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    If there's something strange..... in your neighborhood
    Who you gonna call?
    Ghostbusters!
    If there's something weird... and it don't look good
    Who you gonna call?
    Ghostbusters!
  3. dogfriend
    7,512
    1,188
    Carmichael, CA
    Why that's crazy talk! :madgrin:
    49,692
    i think there is confusion between a stuck pedal and a stuck throttle.
  5. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    How about the people that are "stuck on stupid"?
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    That's an easy one, sell 'em some smart pills. :D
  7. Prius Prime
    Prius Prime Junior Member
    68
    Macomb, MI
    2016 Prius v wagon
    Gee, mine didn't come with a ghost? Where can I get one?
  8. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Presumably the return spring could break, but it wouldn't magically
    un-break itself later when, say, the CHP walks up to the car.
    I don't think it's ever happened, on Denso or CTS...
    _H*
  9. arachnitect
    arachnitect Junior Member
    People (assuming they are not lying outright) could be confused:
    I. Pedal sticks, driver releases foot, loses contact with pedal, and mis-perceives the pedal as having moved rather than their foot. They don't remember "putting it there" because they are unaware of how far they usually depress the pedal when they drive. Thus they are deluded into thinking the pedal moved itself.
    II. The ECU opens the throttle w/o the driver's input. The accelerator is at its return limit, but the driver assumes it is stuck because they can't pry it up (past its rest position). In this case, of course, the pedal could not be "on the floor."
    Really comes down to some combination of:
    1. Confusion (don't perceive or remember event correctly)
    2. Unable to explain what happened properly (they say pedal when they mean throttle, media hack reporter garbles it further, etc.)
    3. People are intentionally lying
    There have obviously been stuck/entrapped accelerators and driver error. I believe there could be ECU "gremlins," but as roverguy says, those would be distinct problems.
    -A
  10. rfelley
    rfelley Junior Member
    42
    Oregon
    Although I haven't studied the system, I have to agree. The Prius gas pedal, when in cruise control mode, doesn't move, but remains at rest in the full up position. This is actually unlike most vehicles and is most noticeable when you wish to cancel the cruise mode while keeping the vehicle at speed. In order to effect a smooth transition from cruise to manual mode you must depress the gas pedal until you feel slight acceleration, then cancel the cruise and gently ease up on the foot pedal to create a smooth transition from cruise to manual mode. If you don't do this you get a sudden deceleration jerking of the vehicle when you cancel cruise een with some accelerator pedal pressure. In most other systems you simply make contact with the accelerator pedal because it is already being pulled by the control to appropriate position, hold it in that position, cancel cruise, and nobody notices.
    OK, now having said that, I still think something is up other than floor mats and sticky hinge points with the Prius problem. If, in the Prius, the engine can accelerate regardless of accelartor pedal position, as when under cruise control mode, then it would be very difficult for the average driver to accurately describe what happened, if say, they were pressing on the accelerator, the car accelerated (due to an uncommanded electronic acceleration signal), they let up on the accelerator, and the car continued to accelerate. Most people would simply say the pedal "stuck".
    I am aware that computer processors can and do make it into the market place with fundamental design flaws mainly because marketing departments press ahead and close sales deals before engineering departments sign off on a given product. Therefore, it is entirely possible that the logic circuits in the Prius models in question could have design flaws that are extremely difficult to identify. As some news reports have stated, I believe most, if not all regulatory agencies with jurisdiction over these types of problems, lack the expertise to fully determine the causes.
    The jury is out on this subject as far as I am concerned.
