For the Coastal experts..
Discussion in 'Gen 2 Prius Audio and Electronics' started by jazba, Oct 28, 2007.
  1. jazba
    jazba New Member
    Everything i think is hooked up properly in my venture to install the coastal tech unit to unlock video but when i hit the mode button to cycle through, the DVD option never comes up. The only wire that i couldn't find anything to plug into is one of the ends of the BLUE adapter that the has the input for the video.
    Any ideas?
    btw its an ultimate lockpick 3
  2. 4n6
    4n6 Junior Member
    36
    With mine,
    1st I have to hit disc/aux untill is says DVD
    2nd I have to hit Audio
    3rd on the touch screen hit picture
    I Hope this helps
  3. jazba
    jazba New Member
    Yeah thats what i try doing, but when i hit the cd/aux button... DVD never comes up. It's as if i never installed the coastal unit
  4. jazba
    jazba New Member
    great costal is out of the office until next tuesday. i get to drive my half nice person put back together prius till then yayy.
    Any body have any idea what the problem could be, besides a bad unit?
  5. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    <div class='quotetop'>QUOTE(jazba @ Oct 31 2007, 01:13 PM) [snapback]532954[/snapback]</div>
    What type of video input device are you using as the DVD source? Is that hooked up and powered?
    If so you should also be able to access the DVD source selection through voice command button.
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Two problems I had at first.
    #1 Using a portable DVD player I had to be sure I hit the "source" button that changed the video output from the portable's screen to the A/V output cable.
    #2 There are two up/down buttons on the steering wheel for volume or changing tracks. I have to hit those bottons to switch between the normal hybrid energy screen and the DVD video screen. This is assuming you already have the "mode" in DVD. When you hit the up/down buttons you must wait a brief moment for the screens to switch so do not hit them back and forth quickly.
