For those who put in LED headlamp bulbs, satisfied?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 4rpr15, Apr 24, 2016.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Or do you prefer another type of bulb or HID kit over the LED?
    iPhone ?
  2. mrbigh
    3,686
    699
    Long Island, NY
  3. Zipsta
    Zipsta Member
    35
    39
    Inland Empire
    HIDs.
    Z.
  4. 4rpr15
    1,056
    375
    WI
    What did you get exactly?
  5. Stephen Ryan
    Stephen Ryan Junior Member
    Wake Forest, NC
    I have a set of PUTCO LED's and not only is the beam pattern terrible, but the built in fan is really noisy. If you're not using the ICE, you get a terrible hum from the engine bay. I've had them in for a while and I'm not interested in swapping out projectors or anything that drastic so I'll probably just settle for crappy headlights. I've tried what was supposed to be a decent set of HID's and didn't like the ground shadow they projected and they actually started to flicker after a while anyway so that's why I switched to the LED. We tried those HID's in a Toyota Sienna and had no issue so I'm not sure what the problem was in the Prius.
  6. 4rpr15
    1,056
    375
    WI
    I heard hid's have issues. One light turns on at times and one doesn't. They also get very hotLEDs are just not bright enough for me is why I'm asking. They look really nice, but they don't go far enough.
  7. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    If you use a drop-in LED bulb in a halogen housing, you're going to have crappy lighting; there's just no way around it. The LEDs will put out a lot of foreground light, which actually reduces your distance vision because of the higher contrast.
    If you want LED headlights, do it right and retrofit some OEM units--they're becoming widely available as people total Corollas, Muranos, Rogues, etc. I have Corolla projectors in mine, and distance lighting is far better than stock halogens.
  8. 4rpr15
    1,056
    375
    WI
    Very true, but it's the $$$ that's holding me back. Hid's look great, but it's just they have too many issues in the Prius. My 4Runner never had issues with hid.
  9. Vman455
    534
    551
    The Middle
    Yeah--but if you check The Retrofit Source, in the closeouts section they often have LED assemblies for not much more than cheap HIDs, and significantly less than a true HID retrofit. Right now they have Nissan Rogue and Toyota Corolla for $100 ($25 less than when I bought them!), and Nissan Murano for $130. Throw in some clear lenses for $40, and you're looking at not much more than an HID drop-in kit or LED drop-ins for OEM quality build and output.
  10. 4rpr15
    1,056
    375
    WI
    Oem is definitely the way to go. I just wouldn't have an idea to do it myself.
    FinToy likes this.
  11. FinToy
    FinToy Active Member
    145
    141
    Finland
    I agree. I just swapped factory LED headlights, couldn't be happier!
  12. 4rpr15
    1,056
    375
    WI
    Where did you pick them up and how much?
  13. mrbigh
    3,686
    699
    Long Island, NY
    A recommended set from The Retrofit Source.
    I used this company since the last 8 years for different vehicles including 3 Prii models.
  14. 4rpr15
    1,056
    375
    WI
    Easy install? I can install an hid set, but I'm not sure about the entire housing.
  15. mrbigh
    3,686
    699
    Long Island, NY
    As easy as it can be. A quote of advise, get the wiring harness plus the relays, it will make your install 100% better.
    Average install time is 2 hs. for a beginner.
    #15 mrbigh, Apr 26, 2016
  16. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    +1 on the HID relay harness. Don't listen to advice that a canbus relay is needed (it's not), or that a relay isn't necessary (it is for reliable power for initial striking of the arc).
    Also, make sure you get the proper H11 bulbs, with the ground wire in the 6 o'clock position after installation, or you will have ground shadows.
  17. Zipsta
    Zipsta Member
    35
    39
    Inland Empire
  18. mrbigh
    3,686
    699
    Long Island, NY
    Sorry but, the referred Ebay item is not compatible with a 2015 Prius
  19. FinToy
    145
    141
    Finland
