Force AC Compressor on?
Discussion in 'Gen 3 Prius Technical Discussion' started by Scott_K, Jul 24, 2021.
  1. Scott_K
    Scott_K Junior Member
    28
    Central NC
    2014 Prius v wagon
    I have a 2014 v that has a (used) (certified) replaced AC compressor. I have went by the book and followed all protocols, down to making sure my gauge set is virgin for the ND-11 compressor oil.
    After setting the compressor, pulling required vacuums, I added the first of refrigerant.
    1/2 can was sucked in and compressor will not kick on,
    I know there is a way to "jump" the HP switch to force the compressor on
    How do I do that???
  2. tre4xw30
    tre4xw30 Junior Member
    37
    US
    I was just talking to my gf about running the electric ac off a power station.
    SM-N986U1 ?
  3. ChapmanF
    15,619
    There probably would be, if the car had a HP switch. In Gen 3 it's a pressure transducer, rather than a switch, and sends the actual high-side pressure measurement to the A/C amplifier, which decides when to run the compressor.
    Are you referring to the Repair Manual (more info) for the procedure you're following?
  4. John in AZ
    John in AZ Junior Member
    Funny enough on my 2nd gen I accidentally overcharged the system and it tripped the compressor out. Fought a while and could not get it to come back on even after getting everything right. But once I disconnected the 12v battery and reconnected it the system reset and worked fine again. So you might try disconnecting the 12v battery for a little bit.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,470
    1,514
    NJ-USA
    What are your system pressures on your gauges? If it's more than 40 psi then that should be enough for the car to allow compressor operation. If it doesn't run then you need a scantool to check for any codes in the HVAC ecu and data that might help you figure out what's going on.
    May also need to check the engine ecu and hybrid/inverter control ecu for problems as well.
  6. Scott_K
    28
    Central NC
    2014 Prius v wagon
    Ahh well thank for the replies. I seen a YT video on how a Gen 2 4 wire pressure switch was jumped to force compressor on and assumed Gen 3 may be able to do the same. I have the eBay version of Techstream and will hook it up this evening to see what it shows. I will report gauge pressures as well. Will also try disconnecting the 12V for a bit. Thanks and I will report my findings here!
    #6 Scott_K, Jul 26, 2021
  7. Brucetafer
    Brucetafer Member
    126
    59
    Orlando Florida
    not even close, the inverter is built in to the compressor instead of being part of the inverter (2nd gen) I did a semi rebuild if you want to check my post
  8. Scott_K
    28
    Central NC
    2014 Prius v wagon
    I understand all that was simply asking if the pressure transducer could be jumped to fool the system and make refrigerant flow with compressor.
  9. tony_2018
    tony_2018 Member
    204
    61
    should be a code if the compressor doesnt kick on. best get the dmm out.
  10. Brucetafer
    Brucetafer Member
    126
    59
    Orlando Florida
    see what happens when you don't think, type, and hit send? im sorry let me try this again..
    Yes.. you can jumper anything, once..
    did you check to see if your ambient temp sensor is working and not missing?
    if you want you can get a kelly controller and force it into running..
    Connector (A) is for the D12 black 6-pin
    The matching connector is a Sumitomo TS-series 6189-1083. This links to the DA1 panel connector then 4 wires to plug A21(A) on "Power Management Control ECU".
    1: "CLK" green to DA1:19 to PMC:19 "CLK"
    2: "DIN" yellow to DA1:20 to PMC:31 "ETI"
    3: "DOUT" red to DA1:21 to PMC:30 "ITE"
    4: "STBI" white to DA1:22 to PMC:20 "STB"
    5: "GND" white-black to DA1:17 to ground point A4
    6: "IG1" violet to DA1:18 to share a 10A fuse in (IG)
    crap I fell asleep at the keyboard again.. ill redo this post if you need tomorrow..
