Force ICE to start before SOC bars purple when A/C on?
Discussion in 'Gen 2 Prius Technical Discussion' started by pasadena_commut, Jul 5, 2025 at 8:20 PM.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,245
    667
    Southern California
    Lately I have had to make a lot of short trips in hot weather with lots of stop and go, and it feels like mostly stop. The A/C is on, the car doesn't get much of a chance to charge when driven like that so the SOC stays in the lower part of its range, and at stops SOC has dropped into the purple bars, often without starting the ICE before the light changes. So when the light changes and the ICE starts the car wants to charge the battery heavily, and then the car doesn't accelerate well.
    It would be better, from my perspective, if I could force the ICE to start sooner, like at one blue bar, when the car has been or will be sitting for a long time. When this is needed the transmission is in D and my right foot is on the brake. I suppose I could put it in P and press the gas, which would start the ICE. Is there a way to do it without shifting out of D or taking my right foot off the brake?
    Sometimes I turn off the A/C to prevent the SOC from dropping into purple. Not a good workaround though because the car heats up very quickly in the sun when the A/C isn't on. Also I worry that it might not be great for the A/C to be turned on and off like that.
    Note: temps in the high 80's or low 90's, although the "outside temp" display is often over 100. That only comes down to something approximating the true temperature with extended driving. This is what comes of putting the air intake next to a lot of hot metal and glass.
  2. dolj
    dolj Senior Member
    8,201
    4,178
    Wellington, New Zealand
    You can force-charge it in D; there is no need to move to P.
    Tombukt2 and Brian1954 like this.
  3. Tombukt2
    Tombukt2 Senior Member
    12,157
    2,144
    Durham NC
    Putting in p will start the ice but I don't notice it charging the car like when I put it in D and hold the brake which is easier for me to do in traffic than for whatever reason I would be moving it to p or N for I think it do not charge them ? I have to be in seriously heavy traffic which I avoid like plague or really driving like I'm lost which is rare. I also do not fit parked w airs on I get the hair out of my car onto someone's free air McDonald's the silly strip mall etc . Prius do not do mobile office worthy at all
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,285
    1,136
    May I ask what your goal is? Why do you think it would be better, from your perspective, if the gasoline engine turned on and started charging the battery before the battery bars got down to the purple ones?
    Remember that the battery isn't really down near 0%, but from no bars to full bars is only something like 30% to 70% state-of-charge, so it's not like it's hurting the battery from deep discharging it.
    It does hurt fuel economy. But then again, using the A/C while driving around in stop-and-go traffic in any car will hurt fuel economy.
  5. Brian1954
    Brian1954 Senior Member
    1,765
    687
    South Central PA, USA
    The correct values are 40% to 80% state of charge.
    #5 Brian1954, Jul 6, 2025 at 9:27 AM
    Isaac Zachary likes this.
