Ford first to use new environmentally friendly paint technology
Discussion in 'Environmental Discussion' started by Tideland Prius, May 23, 2007.
  1. Tideland Prius
    16,128
    Avon Lake, Ohio - The Ford Motor Company has become the first automotive company to paint vehicles using a new 3-wet, high solids-based system. The new technology, which took three years of development and a year of in-plant testing, is environmentally friendly and helps cut costs.
    The new technology uses a high solids-based paint formulation that produces fewer volatile organic compounds (VOCs) and carbon dioxide (CO2) emissions than do water-borne and medium solids-based paints currently used by automakers. The new formula contains more colour pigment and so requires less paint to cover a vehicle. It also allows three layers of wet paint to be applied, one on top of each other, and baked once. This eliminates two paint ovens, resulting in a smaller, more energy-efficient paint shop.
    According to Ford's tests, high solids-based paint provides better long-term resistance to chips and scratches than does water-borne paint. The water-borne formula also requires air conditioning to get the water out of the paint for a high-quality surface, using more energy and releasing more CO2s from the paint shop.
    The company will use the new paint on some 400 U-Haul utility vans, which will be monitored over the next year to collect real-world data on the technology.
    Source: CanadianDriver
  2. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    It is great to hear they are going through some serious testing and trial with the U-Haul fleet. We wouldn't want a repeat of the early eighties switch over to water based paints.
  3. Godiva
    Godiva AmeriKan Citizen
    10,339
    This is great.
    I wonder if Ford and Toyota will cut a deal. Toyota HSD for Ford paint.
  4. tochatihu
    tochatihu Senior Member
    9,046
    3,528
    Kunming Yunnan China
    2001 Prius
  5. Tideland Prius
    16,128
    Interesting. Thanks for the links!
