Ford Focus EV, $39,200
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by billnchristy, Nov 8, 2011.
  1. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    2 people like this.
  2. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    90% ! Wow. That's impressive! :)
    I wish the Prius had this. Smart thinking, Ford! :)
    "Can I get there?"
    Now that's cool !
    Being able to check the charging status from a smartphone instead of having to walk out to the car several times is going to be very convenient.
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Don't mean to be negative, but wow that's steep. I'll bet the Fit EV comes out closer to the Leaf.
  4. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    Its only 4k more base.
  5. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    What is its range? I poked around but didn't see it listed. From the "Range View" picture I'd surmise 40 miles, but that's just a guess. Anyone know?
  6. Trollbait
    12,689
    And the active thermal system for the battery could mean longer ranges in the winter.
    The original anouncement from ford was for 100 mile range. When the Leafs EPA numbers came out, it was dropped to 80.
  7. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    If you look at the brake coach screen 62mi is just over half a tank (say 5/8ths) which works out to 99.2mi.
    Just a guess. :)
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It is heavier and has smaller battery and wider tires than the Leaf.
    Leaf is rated at 73 miles range from EPA. Focus EV should get around 70 miles range.
