Ford Fusion hybrid has the same braking problem?!
Discussion in 'Ford/Lincoln Hybrids and EVs' started by DetPrius, Feb 4, 2010.
  1. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Seems like Ford's problems are not related to the ABS.
  3. freo-1
    freo-1 New Member
    180
    22
    Mass.
    From reading the story on MSNBC, it reads identical to the Toyota problem.
  4. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
  5. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    The momentary "lurch" as the braking transitions from Regenerative to Hydraulic is there in the Fusion Hybrid and Escape Hybrid too.
    Why? Because it uses the same Power Split Device system as the Prius!
    There is also a momentary coasting when braking over a bumpy road, when the computers temporarily cut out regenerative braking in the PSD to prevent the MG2 motor/generator from overloading. This feels like a sudden "acceleration."
    Personally, I don't think it's a problem. It's a predictable behavior that you can anticipate and compensate for as you get used to the car.
    Ford is offering to upload a new version of software to decrease the time it takes to transition from regen to hydraulic, and to make the system less sensitive to bumpy roads so the computer won't do that protective MG2 cut-out as often.
    I think that's what Toyota will be offering for the Prius too-- Just a software upgrade.
  6. Mickey9201
    Mickey9201 Junior Member
    25
    Jax, Florida
  7. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Well, all the psd hybrids, except I haven't seen the Altima nor the HiHy mentioned yet.
    But not IMA, 2-mode, BAS, etc. hybrids. Yet.
    So Ford fixed their brakes 10/17/2009 and CONCEALED this probably fatal safety issue from the buying public?! Oh my...
