Ford Maverick - folks starting to post their "mpg challenge" results.
Discussion in 'Ford/Lincoln Hybrids and EVs' started by farmecologist, Jan 13, 2022.
  1. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Hi all,
    This is pretty amazing to see. Ford Maverick owners are starting to boast about their MPG results on various sites...especially the Maverick subreddit.
    For instance :
    reddit.com/r/FordMaverickTruck/comments/s31h90/just_did_this_today_with_my_hybrid_orlando_to/
    Very satisfying, but also very strange, to see 'truck owners' doing what we have been doing for years.
    I wonder if the sentiment will be any different now that 'truck owners' are doing it? I mean....60-62 miles per hour in Florida?! :ROFLMAO:
    #1 farmecologist, Jan 13, 2022
    privilege likes this.
  2. hill
    8,811
    Disingenuous.
    67 miles does not an EPA rating make EPA is 42 and that's great! (for a pickup) but if the dash reads 29 electric miles? that must have been a serious downhill area for a hybrid - that they picked for a picture. how many posts - here on PC do we have where a newbie posts a picture of driving 40 or 50 miles - nice weather - clear day on a nice downward slope. "Look! ... 100mpg" yea - not.
    #2 hill, Jan 13, 2022
  3. Trollbait
    12,543
    The electric miles displayed is no different than the percent electric the Prius displays. Both are probably better described as time engine was off. Not a metric I'd focus on, as trying to increase the electric side could lead in inefficiency overall in charging the battery. The amount of electric miles here could be a sign that the truck does an auto pulse and coast while in cruise.
    While a single trip isn't a true measure of the vehicles fuel economy, it can show potential. Florida isn't known for its hills, so going downhill likely wasn't a big cause for the results. A tail wind could be a factor, but then tires aren't broken in yet. They were going "Prius" slow for those results.
    Shame it can't be had with AWD.:(
    farmecologist likes this.
  4. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
    Shame I can’t go to the lot and buy a base hybrid, might take years before they open up here
  5. farmecologist
    1,958
    1,799
    Southern MN
    Yeah...it is pretty obvious from the reddit thread that 50MPG isn't to be expected frequently. However, it is pretty cool that it is possible under the correct conditions.
    But c'mon...us Prius drivers have been boasting like this for ages. (y) The point is that it is fascinating seeing 'truck owners' doing this.
    fotomoto likes this.
  6. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    I’ve managed 65mpg OVER A TANK in my C-Max so FORD’s system responds well to hyper-miling and not a parlor trick. I expect the Maverick’s hybrid 3.x system will work even better. Like the C-max, its the high Cd at higher speeds that kills the overall FE. In town (speeds under 60mph), these things will rock.
    They’re available. I’ve seen ‘em on the streets even here in rural south Texas. Maybe at a price (grins)..... but unlike other manufacturers, FORD did make and deliver the $20,000 base XL hybrid along with all the upper hybrid and ICE trims; no waiting for demand to wane for the most profitable trims.
    We hoped that ordering a loaded Lariat would move us to the front of the line but still waiting 8 months later.
    #6 fotomoto, Jan 13, 2022
    farmecologist, hill and privilege like this.
  7. fotomoto
    5,638
    3,814
    So. Texas
    From today on MTC: “Thank you all for the tips and tricks on how to improve my gas mileage! With around 80% highway driving these past 3 commutes, I've been able to get into the 40's!!
    Much better than my last tank at 26MPG. I'm going to continue being conservative with
    my driving and hopefully I'll be close to the 40's for the next fill up
  8. privilege
    privilege Active Member
    659
    169
    Birmingham
    i4 is a garbage commute... you're either doing 85mph or stopped for the last burning car crash that happened a mile past the last exit...
    but
    its flat and straight, you could easily get 60mpg in a Prius there, so if the Ford truck is getting 50 that's pretty good but not going to be typical of hilly terrain
  9. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    Just remember that in-car mpg values are overly optimistic...
  10. privilege
    659
    169
    Birmingham
    mine matches the pump/calculator to within 1mpg normally.
    I record tracks with Gps the majority of the time I'm driving... the odometer is very close on distance traveled also.
  11. Trollbait
    12,543
    It varies by manufacturer. So can be quite close to tank calculated. Gerdes reports on the difference in his reviews at CleanMPG.
    Rmay635703 likes this.
  12. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    Available regionally
    The delivery map shows 90% NON-Hybrids with most of the hybrid deliveries in CARB
    I do not know of a single Hybrid delivery in Wisconsin.
    Im tempted to drive 600 miles to pick up a hybrid Maverick as I tire of my nickel and dime 2001 Dodge that lacks competent HD replacement parts
    I can’t find a first drive review by Gerdes that reports on the Mavericks real world economy nor the EPA Fuel economy cross over speed for the Maverick
    do you have a link?
    #12 Rmay635703, Jan 14, 2022
  13. Trollbait
    12,543
    Doesn't look like he has gotten a hold of a press truck yet.
  14. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    Yeah with under 1200 hybrids on the road I would bet that’s a big problem
  15. Trollbait
    12,543
    He's had the Escape hybrid. It should be close to the Maverick.
