Ford, Prius, Volt Transaxle Disassembled and Explained
Discussion in 'Videos' started by JamesBurke, Oct 25, 2016.
  1. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Published on Sep 20, 2016
    Ford Hybrid Transaxle Generations - (Also Toyota Prius P610 and Chrysler Pacifica SI-EVT transaxles)
    1st Generation (Aisin HD-10) Hybrid Transaxle at 0:30
    2nd Generation (Aisin HD-20) Hybrid Transaxle at 9:53
    3rd Generation (Ford HF35) Hybrid Transaxle at 12:10
    Disassembly of major components at 14:55
    Reassembly of major components at 18:25
    Overall Power Flow at 20:38
    Inverter Converters at 24:04
    Case Comparisons at 27:38
    Weber State University (WSU) - Department of Automotive Technology - Transmission Lab.
    This video shows the components, similarities, and differences of the three generations of Ford's hybrid transaxles from 2005-2016.
    This transaxle design is also used by the 2016 and above Toyota 4th generation Prius with the P610 transaxle as well as the new 2017 Chrysler Pacifica Plug-In Hybrid with the SI-EVT transaxle.
    Subscribe to the weberauto Youtube channel for more great videos. http://www.youtube.com/weberauto
    Visit the following website for information on how to attend our school and obtain an associates degree or bachelors degree in automotive Technology.
    Home
    This video was created and edited by Professor John D. Kelly at WSU. For a full biography, see http://www.weber.edu/automotive/J_Kel...
    Published on Sep 27, 2016
    Chevrolet Volt 4ET50 Transaxle Components and Operation
    General Description at 2:20
    Major Components at 2:50
    EV Mode at 5:00
    Electric Only Combined (Engine Off) Mode at 9:20
    Extended Range Mode 11:23
    Mountain Mode at 14:58
    Disassembly at 16:16
    Powerflow at 23:36
    Summary at 27:30
    This video shows the components and operation of a 2013 Chevrolet Volt 4ET50 Extended Range Transaxle. This transaxle has four modes of operation as well as 4 possible operational states.
    This transaxle design was used in Chevrolet Volts from 2011-2015. The 2016 and above models of the Volt use a different model transaxle.
    I made an error on the Motor B to tire gear ratio, it is actually 7.001:1.
    The planetary gear reduction is (1+(83/37)) = 3.243:1
    The transfer gear reduction is (67/79) = 0.848:1 overdrive
    The final drive gear ratio is (79/31) = 2.548:1
    The result is 3.243*0.848*2.548 = 7.001
    Home
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    WOW, lots to digest. Thanks for posting.
  3. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Every one of John Kelly's videos that I've watched has been nothing short of excellent. I usually link to his video on the P112 to show how Toyota's hybrid gearboxes work.
    It's worth noting that the Toyota P610 actually has a slight simplification as compared to the Aisin/Ford gearboxes that John shows. You'll notice that MG2 and the power split device are geared to separate gears on the intermediate shaft, whereas the P610 uses the same intermediate shaft gear for both MG2 and the PSD. That'll save some weight, although at the expense of some gearing flexibility (the PSD to intermediate shaft and MG2 to intermediate shaft gear ratios are related, whereas in the Ford gearbox, they're not necessarily).
    #3 bhtooefr, Oct 26, 2016
  4. Niels
    Niels Junior Member
    16
    43
    Netherlands
    It's not clear to me what transaxle is built into which prius. In what Prius do I find the Chevrolet Volt 4ET50 Transaxle?
    By the way: Weberauto was my main source of information for making my own video. Great source.
  5. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    It's interesting to compare all of the designs, though, for electronic simulations of CVTs - the two main Toyota designs, the Ford design that Toyota's now using, and the GM designs.
    The Ford video describes very similar designs to the Gen 4 Prius gearbox.
    #5 bhtooefr, Oct 28, 2016
  6. bisco
    49,449
    did gm license their transaxle to toyota?
  7. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    Ford/Prius and Volt Transaxles Disassembled and Explained
    You guys, sometimes I just don't know...
  8. Niels
    Niels Junior Member
    16
    43
    Netherlands
    I read this in the description:
    So, is the 4th generation Prius similar to the first, second or third generation Ford? Is the Prius P610 exactly the same implementation, or just the same overall design? What are the differences?
    I ask because of my own video, in which I made a real effort to get my facts straight:
    Prius Hybrid Drive Explained | PriusChat
    I failed in explaining the exact implementation 3rd and 4th generation. So that's why I ask: Does your video describe the exact built of the 4th generation prius, with every cogwheel, tooth and chain in place, or just a ford-driveline that's more or less similar?
  9. bisco
    49,449
    agreed, that wording is confusing, and makes it sound like prius is getting something from ford, not gm.
  10. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    The Ford and Toyota transaxles are made by Aisin AW which is owned by Toyota. I believe they are all made at the factory at Toyohashi. I don't think it can be said that Toyota is copying Ford in this respect.
    Toyota Motor Corporation and Aisin Seiki are the two major shareholders of Aisin AW, with 51.9% and 42% respectively.
    I think the Gen1 "Ford" and the P610 are similar but the P610 has a decades worth of design improvments. Interesting that the Gen1 Ford had part of a 1 way clutch assembly that was never implemented but now on the Prime it is. Still digesting all this info myself.
    Niels likes this.
  11. Niels
    Niels Junior Member
    16
    43
    Netherlands
    Thanks. That clears up a lot.
  12. fotomoto
    5,602
    3,778
    So. Texas
    "Ford’s decision to bring development of a new continuously variable transmission for its line of plug-in hybrid and hybrid vehicles in house wasn’t due to dissatisfaction with Aisin, the Japanese supplier that provided previous-generation hybrid CVTs.
    Rather, Ford engineers thought they could make an even better transmission while cutting costs.
    The new Ford-developed HF35 transmission, like the Aisin-sourced unit, is an electrified CVT. But it outperforms its predecessor in several key areas, says Shailesh Kozarekar, manager-transmission electronics."
    Ford Says Homegrown CVT Key to Speed, Fuel Economy of New Hybrids | Technology content from WardsAuto
  13. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    The Prius's P610 is a similar layout, but tooth counts are all different, the inverter mounting is closer to the earlier Ford generations (as that video actually does explain), and where the intermediate shaft in the Ford gearboxes uses a separate gear for MG2 and the power split device itself, the P610 gears MG2 and the power split device to the same gear (so there's only two gears on the P610's intermediate shaft, where the Ford has three - and that video missed that).
    I suspect that a more in-depth analysis of what's different would require actually physically tearing down a P610 to compare, and they apparently didn't have one to do that to.
  14. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    The one way clutch shown for the Gen 1 Ford is on the sun gear-generator shaft while the one for the prime it is on the planets carrier-engine shaft.
    We know that with the Prime, the purpose is to allow dual motors drive in EV, but with G1 Ford we do not know to what purpose?
    #14 giora, Oct 28, 2016
  15. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Don't forget about traction-control. There needs to be a means of disengaging. How is that achieved for each of the systems?
  16. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    That wouldn't necessarily be in the mechanical domain, though, it could be on the control side. Just reduce power going to MG2, and command a reduction in fueling on the ICE.
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The video demonstrates how amazingly compact and lightweight the planetary gearset is compared to the 'conventional' helical step gears for same torque rating.
    While in helical gears the full load is carried by only one tooth at a time, in a planetary set (4 planets as we have here) the load is simultaneously carried by 4 teeth in each component of the set.
    So each tooth load carrying capacity is 1/4 of the full load and can be much smaller (width and length) making the 'gear wheel' much smaller as well.
