Formula for hybrid resistance
Discussion in 'Gen 2 Prius Technical Discussion' started by West3rnSpy, Feb 8, 2025.
  1. West3rnSpy
    West3rnSpy New Member
    Las Vegas
    Hello!
    Going through the flow chart of P0A94 / 555 for 2005 Prius.
    I'm confused when It comes to the formula on step 5 & 6, I don't get it. Temperature at the time of measurements was 17c.
    Hybrid Vehicle Motor resistance:
    U - V: 128.4
    V - W: 128.2
    W - U: 128.3
    Hybrid Vehicle Generator resistance:
    U - V: 104.5
    V - W: 104.1
    W - U: 104.3
    Everything checks out and is good for the insulation test and voltage test on the inverter stop test. So far, I'm going with the inverter being toast. :eek:.... Forum won't allow me to post the link to the Charm li diag for this.
  2. West3rnSpy
    Las Vegas
    Crazy how many people have seen this, yet don't want to help explain the math. I fixed the vehicle, I just want to know the how/why behind the math.
  3. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    If the motor temperature is too high, the resistance varies considerably, which hinders determining malfunction. Therefore, measure the resistance at a minimum 8 hours after the vehicle has been stopped.
    Tester Connection Specified Condition*
    U (I14–1) – V (I14–2) Below 135 mΩ at 20C
    V (I14–2) – W (I14–3) Below 135 mΩ at 20C
    W (I14–3) – U (I14–1) Below 135 mΩ at 20C
    Apply the formula given below to correct the resistance.
    R20 = Rt / (1 + 0.00393 × (T – 20))
    R20: Resistance converted to 20 C (mΩ)
    Rt: Resistance between measured lines (mΩ)
    T: Ambient air temperature during measurement (C)
    (f) Calculate the difference between the maximum and minimum resistance between terminals U – V, V – W, and W
    – U.
    Standard: Below 2 mΩ
    The temperature coefficient is used for calculation accuracy due to the fact that the measured resistance differs at different temperatures.
  4. West3rnSpy
    Las Vegas
    I have all that information, it's the formula that I don't understand. I wanted someone to maybe explain how to solve it, or point me in the direction of being able to learn this. Instead of just using chat gpt to solve it for me. I haven't solved a math equation like this in 20 years.
  5. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    R20 = Rt / (1 + 0,00393 × (T – 20))
    R20=128.4/(1+0,00393× (17-20))=128.4/(1+0,00393× (-3))=128.4/(1-0,01179)=129.93
    West3rnSpy likes this.
  6. Hayslayer
    Hayslayer Active Member
    461
    265
    Apparently, I'm missing something. This question seems short on information. Like the formula you're asking someone to explain? Or does everyone here have the flow chart of P0A94 / 555 for 2005 Prius sitting in front of them? Maybe I just don't understand the question.....
    Feels something like: There's a formula on page 92 of the 2005 edition of Encyclopedia Britanica. My result was 82.5 !!
    Can you explain the math behind it?
  7. ChapmanF
    18,532
    As Max demonstrated above, this isn't really calling on you to do much to 'solve' it. It is already arranged so that R20, the thing you don't know, is all by itself on the left of the = sign, so just take the Rt that you measured and the T at the time you measured it, plug those in where indicated on the right, do the arithmetic, and what you get is R20.
  8. West3rnSpy
    Las Vegas
    I was confused because of the crosshair symbol after the RT on the original formula. I've never seen that in school or anywhere else used in math. So I was like... the **** do I do with that.
    *edit.. for some reason this forum wont allow the crosshair symbol to be posted
    #8 West3rnSpy, Feb 14, 2025
  9. MarkySparky
    MarkySparky Junior Member
    30
    Is that milli ohms? (m ohms) or Mega ohms(M ohms)? Uppercase or lower case M or m. Makes orders of magnitude difference in measurements. And where I come from, a completely different test instrument required for proper accurate measurements. I use a Fluke multimeter at home, but Megger megohm meters and milliohm meters in my job at a utility company
  10. ChapmanF
    18,532
    Yeah, nine of 'em. :)
    You need both specialized instruments for poking around the motor-generators. The megohmmeter to make sure the windings aren't conductive to other stuff they shouldn't be. And the millohmmeter to make sure they really do have the right (really low) resistance on the paths where they should conduct.
    The megger readings are more of a go/no-go proposition. Better be a lot of megohms or there's an insulation fault.
    Any time you see somebody bothering to take resistance readings and correct them for the difference between 20 ℃ and the actual temperature at the time of measurement, it's safe to bet that person is looking at the milliohm readings of the actual windings.
    MAX2 likes this.
  11. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    Do you mean this symbol ÷? Enlarged it looks like ÷. If yes, it is not a crosshair, it is the division symbol. I'm not sure why you wouldn't have seen it in your schooling. On computers, it is more easily typed as the forward slash / as MAX2 has done in post #5.
    MAX2 likes this.
  12. MAX2
    MAX2 Senior Member
    1,436
    488
    101
