Forum SLOW, freezes web browsers, etc...
Discussion in 'PriusChat Website Questions' started by Motobob, Feb 11, 2009.
  1. Motobob
    Motobob Seaside Pearl...
    22
    Colorado
    Why is both the older forum website version and the new version so slow, why does it someimes freeze both Firefox and Explorer, and why is it so painful to come here and try and catch on the day's messages? is it a hosting situation because I am on many other forums with more traffic and everything is fast and neat...I am almost given up trying to be a daily reader here.... Bob
  2. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    No problems for me. Speed on old vs. new layout seems to be the same.
  3. slickQUICKprius
    slickQUICKprius I'm awesome!
    291
    Illinois
    The forum freeze my browser quite frequently too - You're not alone
    And yes, all the other forums I'm a part of work perfectly
  4. Tideland Prius
    16,155
    not sure. It works fast on mine. I'm on Firefox.
  5. Radon
    Radon New Member
    120
    Vancouver
    Fast here to using IE
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Good for me unless I open 10 or more tabs then I run a 5% chance of a hanging IE7.
  7. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    My guess is that Flash has some deadlock bugs - it seems to happen more often with multiple flash players in different tabs.
    I'm considering installing IE7Pro and turning on the ad blocker.
  8. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Odd... since the site redesign the site has been blazing fast compared to before.
    I still get the occasional FF hiccup due to resource issues from having too many tabs open, but the site itself seems to be fine for me.
  9. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    There were package updates for Ubuntu, including FF to 3.0.6, GNOME, etc. Will try a Post Quick Reply and see if Ubuntu still has the white screen freeze
  10. jayman
    13,439
    640
    Winnipeg Manitoba
    Danny
    Ok, I still get the white screen freeze, even with all the package updates applied. To confirm, Ubuntu 8.10 is now running FF 3.0.6. - but the status bar now claims "done" instead of "stopped." Opened the error console and here are the most recent ones, from my Quick Reply attempt
    Security Error: Content at Google may not load data from PriusChat Website Questions - PriusChat Forums.
    Security Error: Content at Google may not load data from http://priuschat.com/forums/priusch...8395-forum-slow-freezes-web-browsers-etc.html.
    Warning: Error in parsing value for property 'outline'. Declaration dropped.
    Source File: http://priuschat.com/forums/clientscript/floatbox/floatbox.css
    Line: 1
    Warning: Error in parsing value for property 'height'. Declaration dropped.
    Line: 1
    Error: Permission denied to call method Location.toString
    Error: vbmenu_register is not defined
    Source File: http://priuschat.com/forums/priusch...8395-forum-slow-freezes-web-browsers-etc.html
    Line: 0
    Hope this helps
    jay
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I'm doing okay here with Ubuntu 8.10 and Firefox 3.0.6. This is the same configuration as Jayman's . No white screen freezes.
    Tom
  12. jayman
    13,439
    640
    Winnipeg Manitoba
    :confused:
    When in doubt, blame it on Magic, and start heavy drinking
    Not that I need an excuse for heavy drinking ....
  13. jayman
    13,439
    640
    Winnipeg Manitoba
    I really don't want to think about this much more, but just wondering, Tom, if you added the Flash and Java package to your Ubuntu 8.10?
    It would be interesting for both of us to open a shell, run ps -fu "user name" and compare processes. This may also aid Danny in diagnostics
    Which does NOTHING to explain why XP Pro SP3 also pukes up on Quick Reply running the Windows version of FF 3.0.6
  14. qbee42
    18,058
    3,074
    Northern Michigan
    I never use quick reply. This is a full reply. I do run flash and Java. We seem to be running very similar systems.
    Right after this post I will try a quick reply.
    Tom
  15. qbee42
    18,058
    3,074
    Northern Michigan
    This is my test quick reply. Keep your fingers crossed. Okay, I need to wait 30 seconds to reply.
    Tom
  16. qbee42
    18,058
    3,074
    Northern Michigan
    It hung me up like a winter white out. Obviously it posted, but all I got was a white browser frame. I had to close Firefox and start again.
    Quick reply needs some work.
    Tom
  17. richard schumacher
    7,663
    1,038
    United States
    It also happens on FF 2.0.0.20 under OSX 10.3.9.
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
  19. SageBrush
    11,627
    2,530
    Southwest Colorado
    Oops, happened with FFx 3.06 using OS X 10.5.4 too.
    I think Safari was ok, but I'll have to check again later.
  20. patsparks
    10,664
    567
    Danny, the site seems much faster for me and smoother than it was in the old format but I do need to redo my signature as it's too wide now. I had the lockup problem before with the old format too.
    I think the ad which was after the first post on each page was slowing things down big time, now it's gone the site runs much better for me.
