foul play on my mobil 1 synth oil change at dealership ?
Discussion in 'Gen 2 Prius Main Forum' started by sas0611, Aug 27, 2008.
  1. sas0611
    sas0611 Member
    230
    Well I brought my car in for 10,000 mile service (oil change and tire rotation). I gave them mobil 1 synth and specifically requested 3.5 quarts be put in and that I wanted the .5 remaining quarts given back to me. I was pleased after the service that .5 quarts were returned to me and figured they followed my instructions. My wife drove the car 100 miles and tonight I checked on a few things. First off, I checked the tire pressure in all four tires. It was obvious that the tech rotated the tires without readjusting the tire pressures. Prior to rotation i set the rear tires lower than the front. This setup is the norm on all priuses although some owners may choose to use higher numbers than the placard on the door jamb. Even doing so... the rears are always softer relative to the front. The two rear tires weren't even the same psi - both different. I'm not sure what pattern rotation should be done. One or both of the rear tires were at pressures higher than front and the front's were lower than the rear. 'Nice attention to detail' (NOT) from the dealership mechanic right ? Well at least they did the rotation service... not sure if the rotation order was right or not howerver..
    The oil levels looked correct. Slightly below max mark as should be with 3.5 quarts. Admittedly, the oil was circulating for 100 miles since changed but it looked a bit more yellow than the mobil 1 synth i had from the .5 quarts they gave me back. Also, I had another batch of mobil 1 remaining from previous change done at a different dealership. It didn't quite match in color that batch either. I felt the oils letting a few drops slide between my fingers (don't get too excited... its only oil guys - LOL). Anyway, the oil from the car's dipstick felt quite a bit stickier than the fresh oil from the quart bottle. The fresh synth definitely had much less friction than the stuff from the car with 100 miles on it.
    My question is this... should the oil from the car at 100 miles look slightly more yellow and feel differently. Would the mix of the undrained old oil and the new oil from the oil change cause this to look and feel differently or did the same mechanic that screwed up my tire pressures keep my mobil 1 synth for himself and put the usual dino oil the dealer always uses into my car ? Damn I hate not knowing... Next time I'm changing it myself and self documenting the change. Just had THEM do so it would be documented for warranty purposes.
  2. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    On an engine with any miles on it the oil is going to look different almost instantly once you put it in. The oil change guy is on the clock so he is not going to let the old oil drip out very long before put the plug back in and fills it back up.
  3. Joe_Waters
    Joe_Waters Junior Member
    Illinois
    I had a similar experience at Wal-mart about five years ago. I gave instructions to use Valvoline Durablend in a Chevy truck. I had been doing my own changes for 15 years or better, so I knew just what the oil would look like when I checked the dipstick before leaving the parking lot. It wasn't right, so I went back in and demanded the empty bottles. The tech couldn't produce them, so the manager is called in, I get another oil change while I watch.
    Haven't let another soul touch my hood release since. My three cents worth: it's easy to do it yourself, many landfills will recycle waste oil, and you can only blame one person for the quality of service.
  4. Neicy
    Neicy Member
    834
    Wakefield, MA.
    You could send a sample out for a Used Oil Analysis. Wouldn't that show whether or not it is synthetic?
  5. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    NEICY - cute avatar. question for you. where would you go and who would you call to analyze the used oil? i just had my oil changed and want to know if they really used the oil i gave them or not. hmmmmmm.......this thread adds to my paranoid.............
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Why do you guys who are obviously quite anal have your cars serviced by people you don't trust then fret about it afterwards?
    Of course the dealer clipped your syn oil. Its a CAR DEALER. What do you expect? Your lucky they didn't roll you.
    And as far as warranty work concerning oil changes as posted here maybe 5000 times change the oil yourself & just save the oil & filter receipts. Any idiot can tell if the oil has been changed regularly or not.
  7. Neicy
    Neicy Member
    834
    Wakefield, MA.
    This thread mentions one - Blackstone Labs. Do a search for "analysis" back a year or so, and you will find more.
    http://priuschat.com/forums/care-ma...l-analysis.html?highlight=analysis#post668470
  8. Mr.Vanvandenburg
    Mr.Vanvandenburg Active Member
    927
    302
    For what's worth, I changed my own with M1 from a blend at 8K+. I also noted soon after the oil was clear but yellowish (golden.) I also noted a slight increase in mpg, but (maybe an imagined) mechanical noise increase.
  9. sas0611
    sas0611 Member
    230
    Thanks for the information on the characteristics change of the Mobil 1 after having run the car for a while. You also mentioned that prior to changing it you had a blended oil. Prior to my change I had Mobil 1 (assuming change done prior to the one this week at a different dealership was legitimate). Sorry for sounding paranoid. When I sit back and think about it rationally, the difference in Mobil 1 and Dino oil is maybe 3-4 dollars a quart. Were talking about a total of 4 quarts. Mechanics get paid decent money. Why would they screw around for such a petty bounty. I think they could afford to buy their own mobil 1 synth for their cars and not risk looking shady while on the job. They have to figure that the customer giving them their chosen oil is already highly particular and more likely to uncover something devious than the typical customer who unquestionably pays for all the services the dealer says NEEDS to be done.
