Found a "Electric Supercharger"
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Garron, Aug 12, 2012.
  1. Garron
    Garron New Member
    I found an electric supercharger "For the Prius" here: Faq
    I am not really looking to get an extra gain of performance out of the car, but I was wondering if It would help with fuel efficiency. I know there are complications to go into play, but would love to find out information!
    Thanks!
  2. alekska
    alekska Active Member
    435
    138
    Atl
    No, it will not help. Installing this thing will cost you money and will make gas mileage worse.
    1) you will use electricity (12v) to spin the little turbine = energy use
    2) more air (IF this thing will be able to provide it) will automatically result in more gasoline injected to keep proper fuel mixture ratio = more gas consumption
    3) when not turned on this thing will create a flow restriction = losses
    4) turbine blade will fall off the shaft and damage the AFM sensor and throttle plate or more = big mess
    Just waste of money, IMO.
    - Alex
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  4. Garron
    Garron New Member
    Hi Alex,
    Appreciate the feed back! Do you have any ideas in terms of ways to increase fuel mileage (Besides driving style). I agree with all of your statements above!
    Thanks!
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Do you need all your rear view mirrors? (In my case, the answer is yes)
    Can you do grill blocking some part of the year? (very rarely in Mississippi, more of the year, if you live in the north)
    Michelin Energy Saver A/S tires are among the most fuel efficient.
    Doing all the routine maintenance Toyota calls for using Toyota parts will save gas.
    Wheel alignment and balancing.
    Ruling out changes in the driver really limits your choices.
  6. Garron
    Garron New Member
    I would like to be able to use my rear view mirrors ;)
    I can probably do grill blocking, but would it really help alot?
    I perform maintenance and wheel alignment and balancing regularly, and I also have changed how I drive normally.
    I'm just looking for additional ways. I have found others talking about ways that they charge their "Big" battery which helps them achieve a higher MPG.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Buy a set of good LRR tires. That could boost mpg by 2-3 or even more if you have non-LRR tires on there currently.
  8. Garron
    Garron New Member
    I have to replace tires soon, I will look into that!
  9. bisco
    51,148
    increase tire pressure to max sidewall.
  10. usnavystgc
    3,159
    990
    Tucson, AZ
    You could do this:
  11. Jason dinAlt
    Jason dinAlt Member
    183
    61
    First of all, what kind of mpg are you getting now?
    The 'fix' to get from 35 to 50 is different than what you would have to do to get from 65 to 67.
  12. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    I checked the outfit out with the BBB. They have THREE DIFFERENT SCAMS listed under the phone number listed on the website. All are listed F!!
  13. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    No doubt that there are lots of scams around.
    However, to state that all electric superchargers are scams seems disingenuous.
    Here is why. Lots of cars have been made with belt driven superchargers for decades. These take power from the engine, but the engine ends up producing more additional power then they take out. We can take it for granted that supercharges work. If the ICE can provide enough power to compress the air enough to get more out of the ICE then the naturally aspirated engine, then there is no reason why a properly designed electric motor cannot do the same. Now, why you would want to use an electric motor to do this is not clear to me.
    And I agree, putting a supercharger (or turbocharger) of any type on a Prius is not the way to go.
  14. alekska
    435
    138
    Atl
    Sorry I was not able to answer for a while, and knowledgeable people of PriusChat took the opportunity and suggested a lot of tricks. Make sure to go over old posts - lots of info here!
    - Alex
  15. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    The longer form of that sentence would be "Understand Why 12 volt Electric Superchargers Are Scams" there are 60 volt systems that run out of battery just AFTER the 1/4 mile, for drag racers. An Electric Super charger than ran off your HV Battery might last 30 seconds before the battery was 'empty'.
    Thomas Knight Turbo Electric Supercharger - Tech Review - Turbo Magazine
  16. b2becharger
    b2becharger New Member
    Its possible for a electric supercharger to flow enough pressurized air to make a difference. It takes a little of 1 HP per psi for a small displacement engine. Of course I am talking about a electric supercharger that uses a real compressor and not the ebay sheet metal fan or marine bilge blower scam.
    Home - B2BElectricSupercharger.com
  17. fuzzy1
    10,335
    However, a simple power calculation should reveal that an ordinary automobile's 12V system will be unable to operate such a properly designed electric supercharger motor.
  18. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The OP's referenced unit is a 1 HP blower, but it is only rated for short-term burst use. Our Prii can continuously supply up to 100 amps (1.2 kilo-watts) via the inverter (not the little 12v battery which would be drained quickly) so an electric blower would be feasible if you could make it fit.
    In the early days of the Prius (Gen1) an experiment was done adding a turbocharger to a Prius. It maintained the same MPG and slightly improved acceleration. He limited the boost to about 5 psi to avoid complaints from the ECU.
    AutoSpeed - The Story of Turbo'ing a Hybrid Prius, Part 5
    JeffD
  19. fuzzy1
    10,335
    The OP's blower claims to draw 900+ watts. That leaves less than 300 watts for everything else the 12V system must operate.
    But how much mechanical power is needed to provide the claimed 5 psi boost to a Prius at WOT? Assuming an intake displacement of 1.3 liters (the nominal 1.8 liters is only for the exhaust) at 5200 rpm, the engine is consuming 56 liters of air per second. The 5 psi boost is 34 kpa. The net mechanical power required for this compression is 1940 watts, or 2.6 HP, at perfect efficiency. But accounting for typical electrical resistance, conversion, mechanical friction and turbulence losses, it seems that the gross electrical demand will be closer to the 5 HP (~4000 watts) suggested by b2becharger in post #16.
    So I'm still labeling this as a scam.
    alekska likes this.
  20. Jason dinAlt
    Jason dinAlt Member
    183
    61
    How about if we just say that all aftermarket electric superchargers are scams. :)
