Found a random mystery bolt in the engine compartment
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mathom, Jun 20, 2024.
  1. mathom
    mathom New Member
    Washington state
    Where did this mystery bolt in the engine compartment of my 2007 Prius come from?
    When replacing the fog lights, I noticed a bolt jutting out of the black plastic under (just in front of) the radiator. There is nowhere obvious the bolt could have popped out of. And the size is bizarre too: two inches long, with a 13 mm head. I thought almost all Prius bolts would be 8, 10, 12 or 14 mm? The writing on the bolt head is illegible. I swear I didn't do anything that could have caused this :) priusbolt1.jpeg priusbolt2.jpeg
  2. Tombukt2
    Tombukt2 Senior Member
    8,873
    1,548
    Durham NC
    See the little flange around the head You see those in various places on the car like in the timing cover and things like that found it on what side of the car?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,423
    1,482
    NJ-USA
    I have never seen a 13mm hex on a Toyota. The 8.8 on the head indicates the "hardness" of the bolt.
    Likely someone just was looking to replace some missing fastener and dropped it while underhood. Gravity never misses a chance to make you grumble and curse.
    PriusCamper likes this.
  4. Mendel Leisk
    38,630
    Did you determine it was 13 mm (socket size) by testing with a 13 mm socket. Maybe not even metric, a 1/2” (socket size)? If you’ve got a caliper or micrometer check diameter at the threads.
    Just a guess: it’s not from you car, just kicked up from the road while driving.
  5. Tombukt2
    8,873
    1,548
    Durham NC
    I think that's the length maybe about a half inch hell I don't know I don't have the copy of the picture against the Swanson scale but that is a Toyota bolt I've got a bunch of them over here in the thing and I may even have a match for it but I'm not sure where it goes usually with the extra little lip around the head of the bolt you know so it can't bury itself on a socket all the way up to the threads is usually clamping something with the gasket or FIPG like the timing cover not that this is where that came from generally speaking one would hope. And then I have a bunch of these on my Italian motorcycle exactly like this with the same dimple in the head and everything but not the point at the end of the threaded shaft which indicates to me that might penetrate and go into an open hole not flat like a blind hole thread
  6. mr_guy_mann
    3,423
    1,482
    NJ-USA
    Again, 8.8 on the bolt head is a "metric only" hardness rating. You will not see that on imperial bolts. Given a 13mm hex, it looks like a 8mm x 1.25 pitch, about 40mm long.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
    This is not a Toyota OEM bolt.
    All Toyota bolts use the Japan Industrial Standard (J.I.S.).
    All M8 J.I.S. standard bolts use a 12mm hex head.
    Toyota bolts are never marked 8.8. They are marked with a "9."
    Brian1954 likes this.
  8. douglasjre
    douglasjre Senior Member
    1,851
    646
    Orlando, FL
    Prius doesn't use that bolt anywhere
  9. ColoradoCrow
    ColoradoCrow Active Member
    967
    392
    Leawood, KS
    I
    Did you park (too close) next to a Gen 2 Range Rover? Stuff fell off mine all the time....(y)
