Found grease all over inside wheel?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rocinante1984, Aug 6, 2019.
  1. Rocinante1984
    Rocinante1984 Junior Member
    Moscow, ID
    Found greenish colored grease all over inside the wheel while changing oil. Recently had this tire repaired.
    CV boot looks fine. Wheel bearing maybe a little off center? Can't figure out the problem.
    Also the back side of my rotor has a scratch on the middle and thst brake pad is much lower does this mean my caliper has failed or that the brake pad needs replaced?
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Look at the boot closer. Bet you find a crack in it.
    edthefox5 likes this.
  3. Rocinante1984
    Moscow, ID
    Yep.
    So... As it turns out the CV boot doesn't come off and you're supposed to order an entire new axle and drain the transmission fluid to do this.
    1cm tear on boot.
  4. Mendel Leisk
    41,901
    I think you can pull the whole thing off, disassemble, repack the joint with grease, slip on a new boot and reclamp it. But that's a lot of labour, and rarely done now. There's also "split" boots, not sure how well they hold up.
  5. frodoz737
    frodoz737 Top Wrench
    4,720
    2,517
    33
    Not very long. Easier and faster just to change the half shaft.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Just did the half shaft replacement on a 91 Corolla with @The Critic :).
    That’s what I’d do is replace the shaft :).
    Easy peasy (y).
    SFO and frodoz737 like this.
  7. Patrick Wong
    18,210
    6,513
    The OP also asked about uneven brake pad wear, usually that is due to the caliper slide pins not sliding freely so that the braking force is transmitted only to the one pad. The solution is to replace all four pads on the front axle and to properly lubricate the slide pins. If the rotor is damaged that should be replaced. Here is a relevant recent post:
    My front brakes were neglected! What happened and how I fixed it. | PriusChat
    The OP will look up the price of a new Toyota half shaft and fall on the floor. Then he is going to ask about the price and availability of aftermarket parts. I understand that aftermarket drive shaft parts quality is not very good; is there a group consensus on that?
  8. Leadfoot J. McCoalroller
    8,146
    7,645
    Pennsylvania
    2018 Prius c
    Over in Subaru forum territory (with 2x the halfshafts) it is commonly accepted that you’ll net a better axle by regreasing and rebooting your OE axle instead of hanging a remanufactured unit. Too many QC issues, especially with lash.
    Mendel Leisk and Patrick Wong like this.
  9. Patrick Wong
    18,210
    6,513
    Yes, and I have seen some advice to the effect that it is better to buy a used original equipment half shaft from a salvage yard, than to use a new aftermarket part of dubious origin.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Op never mentioned miles on the car. Cv joints on this car are very high quality don’t see lots of posts about them failing.
    They fail fast with no grease though.
    Many posts of issues with after market joints. Oem are expensive.
    To lurkers easy to prevent ripped boot just condition it. Lots of rubber boots up front the cv boots and the steering linkage. Just apply rubber conditioner to the boot when under there doing oil change.
    I use black magic conditioner works great.
    #10 edthefox5, Aug 7, 2019
  11. Patrick Wong
    18,210
    6,513
    My guess is the boot tore because the tire was flat ...
  12. Leadfoot J. McCoalroller
    8,146
    7,645
    Pennsylvania
    2018 Prius c
    ^ Debris (strip of tire or things kicked up from littered road shoulder) can rip them. Snow and ice can contribute to this.
    The worst is dirt and water getting IN to the joint. That will wear the races quickly, and once they’re pitted or galled it’s over.
  13. frodoz737
    4,720
    2,517
    33
    Rocinante1984 the option you take depends on how long you plan to keep your vehicle...and how much you want to spend. Aftermarket half-shaft regrounds found at the corner auto parts stores and/or used OME will "generally" give you 1-2 years of service. Repack/reboot requires more labor and tooling and there's no guarantee wear is not already out of limits. OME new cost more, but will be the last time you have to deal with this considering it's a 2007...but I would advise changing both sides at the same time so you are not back under the car next year. Also be advised when doing this work you will need to repair any other issues you discover while everything else is apart. Of course doing nothing is the cheapest and financially wiser choice if you are "already" eyeballing a replacement vehicle, because you will not recover the repair costs in the trade-in or sale value of this 12+ year old car. The work is easy if you can turn a wrench...or have a "competent" friend that works on beer/burger commision. Best wishes. ;)
