found this dangling in wheel well today
Discussion in 'Gen 2 Prius Main Forum' started by Rooslix, Jul 7, 2018.
  1. Rooslix
    Rooslix Junior Member
    Utah
    Anyone know what this box is?
  2. Rooslix
    Utah
    I says “den so” on it. Also my keyless entry no longer works so wondering if it’s related?
    49,397
    unsure, but dense is the spark plug, so maybe part of ignition system?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Not seeing the fender liner there, did you strike or hit something?
    Did any lights illuminate?
    How long has the wiring been dangling?
    Does the Prius perform the same as it did prior to finding this?
  5. JK919
    JK919 Member
    47
    33
    Cary, NC
    A GPS tracker. You've clearly made some powerful enemies.
    chelvis, bisco and SFO like this.
  6. GTW
    GTW Junior Member
    55
    23
    Castroville
    Has anyone flipped the switch under your steering wheel, where the 'smart' key system can be disabled to save battery drain?
  7. Rooslix
    Utah
    I tried unlocking the doors and a beeping sound is coming from the dangling box so you guys were right! No idea where the proper place to put the box is so it won't dangle. Also, my smart key button under steering wheel was depressed so I pushed it and now my smart key works AGAIN! Thank you thank you thank you! My 2 year old must have pushed it.
    GTW likes this.
  8. dolj
    dolj Senior Member
    7,631
    3,849
    Wellington, New Zealand
    It is supposed to go here, apparently:
    (y)
    Evangeld, maverick1970, SFO and 3 others like this.
  9. Mendel Leisk
    38,653
    Just to help out:
    #10 Mendel Leisk, Jul 10, 2018
    Evangeld and SFO like this.
