  1. Dodgerfan
    Dodgerfan New Member
    Los Angeles
    I have a 2006 prius. A couple days ago, i turned on the power button, and approx. 10 seconds later the car started beeping four times. It has been happening ever since. Only after I start the car. Can someone help me? Thx.
    49,437
    does it do it every time you start it? is everything else o.k.? runs fine?
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Do you still have the original 12V battery? If so, yours is getting to that age where they often fail.
    Tom
  4. richard schumacher
    7,663
    1,038
    United States
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It could also be the battery in your fob. Change that first to see if the beeps go away. It's cheaper than the 12v battery. You can also use your spare fob as a check.
  6. hschuck
    hschuck Member
    385
    17
    bay city, ca
    Fob battery is 1 beep on shutdown.
    (Gen II data; probably unchanged.)
  7. firepa63
    1,761
    208
    With the Prius, I always try the least expensive possibility first...
  8. Dodgerfan
    Los Angeles
    Thanks to all who replied to my problem. I tried my spare fob yesterday and that wasn't the problem. And I just tested the 12v and the voltage was 12.3, so I'm 99% that is the problem
    My next question: Should I take it to the dealer to replace or can I have a mechanic at Sears do the job? You know how sensitive those Toyota mechanics are. Thanks again.
  9. firepa63
    1,761
    208
  10. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Given the same data I would be more like about 1% certain (at best) on that conclusion. A 12.3 volt battery measurement does not necessarily indicate a problem.
  11. a_gray_prius
    2,927
    782
    IL
    +1 on the key fob battery running down. One relevant observation on a car with the smart key system on is that when you leave the car in READY mode, and then take the key out of the car, it will beep 4 times. If the battery is failing, the beeps may suggest that the fob signal may have been interrupted due to a dying battery (no power to transmit).
  12. ursle
    ursle Gas miser
    1,049
    192
    NH
    The dealer will just hose you, order the Optima battery with installation kit and have 4-8 years of peace of mind.(also change the fob battery)
