FR-S rims on Prius: Anyone else use spacers?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mmm, Oct 29, 2012.
  1. mmm
    mmm Junior Member
    25
    What type of spacers did you guys use? where from?
  2. 4npower
    4npower Junior Member
    79
    VA
    Do a search , there was a post about a month ago where a member did this swap and listed where and what size spacers he used.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I answered you before. 5mm spacers.
  4. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    I'm running 10mm on the rears.
  5. tihsad
    tihsad Junior Member
    93
    So. California
    although my car is still at the shop, i'm planning to run 3mm all around for my BRZ wheels. i wanted the minimum as possible. if it doesnt work out, then im going with 5mm
  6. mmm
    mmm Junior Member
    25
    What are you guys doing about the 2mm difference? No one will make hubcentric rings that are 2mm. Does anyones car wobble at high speeds?
  7. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    Mine doesn't.
  8. mmm
    mmm Junior Member
    25
    I see. I'm getting mixed answers about having to take care of the 56.1-54.1mm difference.
  9. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    I don't have a shimmy..just roadforce balance it
  10. wreavis
    wreavis Junior Member
    Santa Rosa, California
    going to get these installed today....will post updates 2012-11-07 10.28.24.jpg
  11. Xaran
    Xaran Junior Member
    95
    I like those FRS wheels. I cant understand why there are so many sets available, if I had a new FRS Id spend the $ on something else first, those wheels look great on the car IMO
  12. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    If you can get a set with the Michelin tires...the bridgestone's suck
  13. mmm
    mmm Junior Member
    25
    You guys are just using hubcentric spacers without hubcentric rings?
  14. wreavis
    i used the 3mm standard spacers... been driving on the freeway everyday since...no problems
    seems like i'm getting about 2-3 more MPG will know for sure next fill up 2012-11-10 13.23.04.jpg 2012-11-08 15.19.46.jpg
  15. tihsad
    93
    So. California
    i also did 3mm and the caliper clearance is like 1mm.. maybe i should have went with 5mm but seems like there are no problems for me either
  16. mmm
    mmm Junior Member
    25
    What is the bore of the prius? The fr-s rim is 56.1.
  17. tihsad
    93
    So. California
    looks like about 5 - 10% drop in MPG for me too. only thing is that i was on my rental for like 7 weeks so i kinda lost the feeling of driving on ECO mode. I've put 160 miles till now and i'm getting 48MPG as we speak
  18. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    That sounds about right. 4mpg+- is what most people lose unless you are a hypermiler in which case it's more. :)
  19. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    3mm actually.
    F8L likes this.
  20. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Didn't you say the 3mm were cutting it close or was that someone else?
