Free nitrogen tire fill-up at Costco?
Discussion in 'Gen 2 Prius Fuel Economy' started by Danny, Aug 18, 2004.
  1. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
  2. jamarimutt
    jamarimutt New Member
    985
    The air we breathe and pump into our tires is already about 78 % nitrogen. How can an additional 22 % make any difference in terms of safety and handling? Also, where would you fill-up regularly in order to maintain accurate pressure? Not worth it, IMHO.
  3. LeVautRien
    LeVautRien Member
    379
    New Orleans
    Where would you fill up regularly? Costco :mrgreen:
    I think that's the point. But I'm a Sams person myself, being from the south and all, so I'll drink my Coke and not get my Nitrogen. :mrgreen:
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I obviously need a education. Is this good? Why nitrogen?
  5. onerpm
    onerpm New Member
    477
    MN
    Not only that, but costco will also rotate them for free (no matter where you bought the tires). For $4 per tire, they will rebalance them.
    rpm
  6. LeVautRien
    LeVautRien Member
    379
    New Orleans
    From what I read, I think I gathered that in theory, it expands less than normal air when heated. It's a sporty/racing thing, so probably on par, practicality-wise, with getting a spoiler on your Prius.
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    ooh!! ooh!! one of those big erector set ones (like I had when I was 7). Now where can I get high performance door handles. Edmonds!!
  8. LeVautRien
    LeVautRien Member
    379
    New Orleans
    And let's not forget the engines they put in just about any car these days in terms of practicality. :mrgreen:
  9. Gen2
    Gen2 Member
    319
    I recall that race cars have been using nitrogen in their tires for many years so I decided to give it a Google. Now i'm hooked. Does anyone know tha real deal behind using nitrogen in street tires?
    If it is really better, then how do we get all that old nasty air out of there so we are sure that there is only nice pure nitrogen in there?
    Does it improve fuel economy at all?
    http://www.aftermarketbusiness.com/afterma...l.jsp?id=101650
    http://popularmechanics.com/automotive/sub...504/print.phtml
    Then I found this topic has made the rounds on Priuschat before:
    http://priuschat.com/forums/archive/o_t/t_...lled-tires.html
    OOh, I'm getting dizzy from all those nitrogen fumes. :)
  10. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    "OOh, I'm getting dizzy from all those nitrogen fumes. "
    It's the nitrogen bubbling out in your blood stream. You may have the bends. Go straight to the nearest hyperbaric chamber a few sessions on O2 at 66 feet that should fix it. You need to be cleansed of the excess nitrogen before a bubble strokes you out!
  11. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    How about filling the tires with helium to make the car lighter?
  12. jamarimutt
    985
    Costco will rotate your tires for free because they bet that many folks will also want their tires balanced for $4 each. :roll:
    Costco will inflate the tires with nitrogen for free because they know that many folks will come in the store and buy a bunch of stuff they don't need. :roll:
    A tire inflated with helium will practically weigh the same as one filled with air, and it will certainly won't float. Also, I doubt that Costco will inflate with helium for free. :D
  13. Gen2
    Gen2 Member
    319
    Yes it would work but the car would only be up to 2.6 ounces lighter.
  14. Gen2
    Gen2 Member
    319
    Actually I'm starting to like that bubbly feeling, who knows, it may improve my personality too :)
  15. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Helium is such a tiny atom, it probably will leak out through the tire in no time at all. Just look at a helium filled balloon, it's deflated overnight.
  16. Smooth Operator
    172
    Cowichan Bay, BC Canada
    The air in our environment contains only 0.0335% CO2. How can changing it to only 0.0400% make any difference in terms of global warming?
    One of the principles behind the Prius is that small changes can make large differences.
  17. daniel
    14,487
    1,518
    Spokane, WA
    The place where I have always bought tires uses nitrogen. No extra charge. They seem to think it's good. I don't care. When they get low I top them off with air.
    The advantage of filling your tires with helium would be that if you ever need to speak in a squeeky voice you could just get down on your hands and knees on the pavement and inhale some air from a tire. And if you drive a monster truck that 2.6 oz advantage might grow to a pound or so.
    Comic book superhero: HelioPriusMan: At critical moments in his adventures (e.g. cat in a tree) he causes the helium-filled tires of his Prius to get really big and his Prius rises like a blimp.
    The heck with yachts and learjets and 78-million-dollar subs. I want a blimp. Or a dirigible.
  18. RonH
    RonH Member
    556
    Back before bicycle tech went all titanium and carbon fiber there was a lot of effort to lighten up by drilling holes in the components, using short pitch chains and so forth. One of the tricks for track racing (short duration events) was to use helium in the tires. Not only did it save weight but rotational weight, the best of all. And made for some high pitched fun onthe infield between races. Unfortunately, such hi tech bikes also tended to have lightweight tubes which were very permeable to those little bitty helium molecules. I don't recall seeing any real discussion of what the tradeoffs were including the increasing rolling resistance as the race went on. Since I was always saddled with 10 lb spare tire I couldn't see what all the fuss was about.
  19. N9IWP
    N9IWP New Member
    148
    Southeast MN
    I remeber reading about helium fillesd tires for Olympic bikes. It doesn't make much a dufference, but when races are measured in thousandths of a second, every .01% helps.
    By the way, blimps ARE dirigibles. "dirigible" means "steerable" not "rigid"
    Brian
