Free weekend for maintenance on 2010 and 2012 priuses (prii?)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Whiteheat, Jul 12, 2019.
  1. Whiteheat
    Whiteheat Junior Member
    Northeast Ohio
    I have a 3 day weekend coming up that I plan to do maintenance on my 2010 prius with 225000 miles (and does not burn oil yet...) and friend's 2012 prius with 110000 miles and burns oil.
    Any recommendations for what should and can be done? I plan to pull them each into a separate bay and do the same things to both one after each other.
    I plan on doing these since they have never been done as far as I know:
    • Clean EGR and EGR cooler
    • Clean intake manifold
    • Add oil catch can
    I am also going to use an engine flush (BG 109 EPR) on both and change the oil. On the one burning oil, I may do 2 flushes to try to get the piston rings cleaned more.
    The trans fluid needs changed on both (2010 done at 190k when I got it, 2012 never done as far as I know).
    Anything else I should do while I am in there?
    Raytheeagle likes this.
    49,500
    110k is close to coolant changes and plugs i think. check the recommended maintenance schedule
    m.wynn likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Trans drain and fill ever been done on either?
    m.wynn likes this.
  4. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Was EGR tract ever cleaned out previously on the high-mileage one? Let us know how that goes, please. Thanks!
    m.wynn and Raytheeagle like this.
  5. Whiteheat
    Northeast Ohio
    Trans drain/fill was done on 2010 @ 190k when I bought it. Plan on doing again to both for good measure.
    As far as I know, the EGR was never touched on the high mileage car. I will take pictures of that whole tract.
    I will also do the plugs on both since I am in there.
    Thanks everyone!
    CR94, mjoo and Raytheeagle like this.
  6. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I was going to say that spark plugs are pretty obvious. If you take the intake manifold out to clean it and the throttle body, there are some Toyota gaskets you’re supposed to replace, although not everyone does.
    Remember that engine coolant circulates through the EGR cooler.
  7. Whiteheat
    Northeast Ohio
    Started tonight. Got both coolers off and they are soaking. The 2010 was almost completely clogged, very little fluid went through when I tried to clean initially. Really just little drips. I guess about 95% clogged.
    I bought Main Line cleaner from Walmart that is basically lye (see picture). Much stronger than oxyclean. This stuff had the ends perfectly clean in about 30 minutes. They are both soaking overnight. The 2012 was pretty bad about 70% clogged.
    I'll.get pictures in a few days as I won't have much time tomorrow but will update after the weekend. 20190719_200430.jpeg 20190719_200437.jpeg 20190719_213812.jpeg 20190719_213821.jpeg 20190719_213829.jpeg 20190719_213933.jpeg
    RMB and Mendel Leisk like this.
  8. Whiteheat
    Northeast Ohio
    After a lot of work, both are back together.
    The Instant Power Main Line cleaner really cuts the grease/sludge/carbon.
    The 2010 had an extremely bad caked in area of sludge where the PCV connects to intake (picture attached). 20190720_101320.jpg 20190720_102602.jpg
    Some after pictures attached. I did not get any pictures of the OCCs installed but that went easy.
    20190719_215516.jpg 20190721_144219.jpg 20190721_144252.jpg 20190721_144253.jpg
    RMB, Mendel Leisk and Raytheeagle like this.
  9. NewHybridOwner
    NewHybridOwner Active Member
    607
    282
    W. Michigan
    Where did you use the lye? Not on anything aluminum, I hope (I'm not sure which parts are aluminum and which are stainless steel).
  10. Whiteheat
    Northeast Ohio
    I got the concentrated lye at Walmart - 1 gallon. See picture above. It was called Main Line Cleaner Instant Power Main Line Cleaner, 1 Gallon - Walmart.com
    I did not soak any aluminum parts but only the stainless parts which came out sparkling!
    CR94 and Mendel Leisk like this.
  11. ASRDogman
    ASRDogman Senior Member
    6,092
    3,273
    I guess that stuff cleans like oven cleaner. Did you use a pressure washer to rinse it out, or just
    the regular garden how sprayer?
  12. Whiteheat
    Northeast Ohio
    My pressure washer is down for the count currently so used a garden hose with jet sprayer.
    I'd like to make a recirculating pump that hooks up to one end and continuously flushes the lye solution through the cooler. Maybe even incorporate a filter of some sort. Maybe next time.
  13. Mendel Leisk
    38,728
    Those pictures are a black-eye for Toyota's engineering department. :mad:
    Whiteheat likes this.
