Frequent Rattling Even with Engine Off
Discussion in 'Gen 2 Prius Main Forum' started by RandallG, Jul 20, 2017.
  1. RandallG
    RandallG New Member
    Boulder, CO
    2008 Prius. Since I bought this car almost 10 years ago, there has been a persistent, frequent rattling noise that seems to originate from just behind (or possibly from within) the hybrid synergy drive. Of late, it has become much more frequent. It happens when I am driving or even when the engine is turned off.
    When I am driving at a constant speed, this rattling, which last for about 3 seconds, occurs about every 8-12 seconds. When stopped it occurs about every 22 seconds. It happens almost immediately when I begin braking.
    Even after the car is turned off, the rattling occurs at very frequent intervals (less then 30 seconds) for up to quite a few hours unattended.
    I have a video of this, but this site won't let me post it. Message me and i'll send you a link.
    Where is this coming from? Is it a part that can be replaced somewhat inexpensively? Anything to worry about?
    Thanks. Any advice is appreciated.
    49,597
    just post 5 quick posts, and then you can upload.
    never heard of anything like it, the video should be interesting.
    it's not the buzzing noise that happens when you first open the drivers door, is it?
  3. RandallG
    RandallG New Member
    Boulder, CO
    I also need to wait one day since I just registered. I posted 4 empty threads. Will attach a link tomorrow if it will let me. Thanks for the quick reply.
  4. Johnny Cakes
    Johnny Cakes Senior Member
    1,020
    766
    Virginia, USA
    The engine off comment is interesting -- any chance this is related to or coming from the a/c blower fan?
  5. FuelMiser
    FuelMiser Senior Member
    1,302
    889
    Monument, CO
    First, you might try posting in the Gen 2 Forum, the one for your car...apparently you can "Report" this post and the moderator will move it.
  6. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    A malfunctioning brake accumulator(pump) will run too often but typically it's not very loud and very difficult to hear while the car is moving. It can't maintain pressure so it runs too often. Mine wasn't any louder than it does when you first open the drivers door.
    Any codes/warning lights?
    #6 fotomoto, Jul 21, 2017
  7. Patrick Wong
    18,200
    6,479
    The brake actuator pump is probably beginning to fail. This is the subject of an extended warranty. I recently posted about getting that pump replaced on my 2007 under that warranty.
    See my post #68 here: Brake Actuator Assem - Warranty Enhancement | Page 4 | PriusChat
    Kevin_Denver likes this.
  8. bisco
    49,597
    he said it's been doing it for 10 years, and as of late, it's become much more frequent.
    see my last sentence in post #2.
  9. RandallG
    RandallG New Member
    Boulder, CO
  10. Patrick Wong
    18,200
    6,479
    That is the brake actuator pump, which is located on the firewall. You need to remove the tray which houses the windshield wiper motor for access.
    Are any skid control ECU warning lights on (such as ABS, VSC, ((!)), or BRAKE)?
    Even if no warning lights are on, it is possible that DTC may be logged. Use Mini VCI to see if any are present. If so, your car may qualify for coverage under the extended warranty.
    Otherwise, if you have to replace the pump yourself, you could install a used unit and use Mini VCI when purging air out of the hydraulic system. Consult techinfo.toyota.com for repair manual info, as you do not want to screw up the brake system based upon incorrect repair technique.
    #10 Patrick Wong, Jul 23, 2017
    valde3 and jerrymildred like this.
  11. RandallG
    RandallG New Member
    Boulder, CO
    Thanks, Patrick. I've been listening to that sound for a long time. I was told it was 'normal' but I should have been more skeptical. I'll look into getting it replaced under an extended warranty.
    Thanks again!
  12. Patrick Wong
    18,200
    6,479
    The presence of the sound is normal but a high repetition of the sound is not.
  13. Tideland Prius
    16,170
    It is ridiculous. How about posting like a normal person instead of posting empty posts?
  14. bisco
    49,597
    not unusual for a 9 year old car. as patrick said, it's normal, until it's not.
