Fresh air through vents without running heat pump.
Discussion in 'Gen 5 Prius Main Forum' started by UmpireRips, Apr 9, 2025.
  1. UmpireRips
    UmpireRips Junior Member
    Colorado
    2024 Prius Prime
    Anyone know how to draw in fresh air with the fan without having the heat pump turn on?
    We have a ‘24 Prime and if the car is hotter inside than outside we’d like to put it on fresh air mode and run the fan, however, whenever we turn on the fan the remaining milage indicator drops and the air conditioning kicks in.
    PrimeDan likes this.
  2. KMO
    KMO Senior Member
    1,971
    699
    Finland
    2023 Prius Prime
    The A/C enters automatic by default when you press AUTO, despite the light not being visible while it's automatic.
    To temporarily manually turn it off, press the A/C button twice - first time to put it manually on, second time to manually off.
    Then it will be off until you press the AUTO button again.
    There's an option in the settings to not have the AUTO button apply to the A/C.
    Exhaustively covered in this thread from last month:
    Bugs? (A/C and auto-high beams) | PriusChat
    And the remaining mileage indicator isn't very smart - it doesn't seem to adjust its "climate control deduction" based on whether the A/C is enabled, or any real load indicator, so don't look at that for an indication of whether the heat pump is engaged. (The car does know what the current climate kW load is - you can see it on a scan tool, or affecting the My Room power display - but it doesn't seem to use it for that range display).
    Winston Smith and PrimeDan like this.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,174
    576
    Alberta
    2024 Prius Prime
    XSE
    Open some windows.
    RandyPete and Mendel Leisk like this.
  4. UmpireRips
    Colorado
    2024 Prius Prime
    Thanks, very useful, I’ll check out the link, I do have the option for not having the AUTO mode turn on the air conditioning, but when the fan speed is bumped up it seems to turn it on.
    I was just waiting for someone who has nothing better to do but to post useless comments to chime in, didn’t have to wait long.
  5. bisco
    52,053
    the software is programmed to reduce estimated range when you turn the fan on. they have done it that way for 13 years, no one knows why. the heat pump is not coming on.
  6. mva
    mva Member
    139
    83
    B.C. Canada
    2024 Prius Prime
    SE
    I have noticed that if I select outside air and then turn the heat/ac off I can get some air coming through the vents by cracking a window just a little - no fan running.
  7. Dany Dan
    Dany Dan Junior Member
    48
    23
    Québec, Canada
    2024 Prius Prime
    SE
    If you do not want the heat pump to work and be only in ventilation, lower the temperature at the bottom of 15 degree Celcius and at this time, the indicator indicates LO.
    When the temperature is at LO, the heat pump is stopped.
