Fresh Air
Discussion in 'Gen 2 Prius Main Forum' started by Deanlu22, May 23, 2007.
  1. Deanlu22
    Deanlu22 New Member
    Is there a way to set air vents to get fresh air only without using the fan??
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Set the air conditioning to manual, outside air, and fan at the lowest setting. You will need the fan to get much air.
    Tom
  3. bulek
    bulek Junior Member
    44
    I would do it in a different way (from my experience). Set temperature to the lowest possible level and then turn A/C completely off. If you do it without adjusting a temperature the incoming ait will still be warmed up.
    - Piotr
